93 civic startup problem
Old Oct 30, 2011 | 02:58 PM
JStroupe's Avatar
Default 93 civic startup problem
I have a 93 civic coupe that had a z16z6 motor in it but i blew it up. so I dropped the only thing i could find into it and so i put a d15b7 in it. Everything is fine besides when I start it up the temp is always on cold which im guessing is because its been cold outside in the mornings. but when I put it in reverse it seems to bog down alot and sometimes just cutting off. Also sometimes when i start it up it bogs down really bad and i have to rev the motor so it doesnt die. and after doing that for a little while it is fine. idk if this is a problem that can be fixed or if its normal?? anyone have any ideas? it runs perfectly fine once i can get it going lol
Old Oct 30, 2011 | 03:14 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 93 civic startup problem
What ECU is in it now?
Old Oct 30, 2011 | 03:24 PM
JStroupe's Avatar
not really good at these kinda things. but it is whatever that comes stock in a 93 civic coupe ex
Old Oct 30, 2011 | 03:26 PM
JStroupe's Avatar
could it maybe be my throttle cable?
Old Oct 30, 2011 | 03:35 PM
The Grumpiest
These aren't old V6/V8s that you can simply swap in like puzzle pieces.
Why are you not running the ECU for the new engine?
Are there any CELs?
Old Oct 30, 2011 | 03:36 PM
JStroupe's Avatar
do i need to? is that what the problem is?
Old Oct 30, 2011 | 03:49 PM
The Grumpiest
Why do you think you wouldn't?
Again, any CELs?
Old Oct 30, 2011 | 04:01 PM
JStroupe's Avatar
Again, any CELs?
how do i check the CEL thing? sorry im a nooby.
im thinking its cause of the wrong ecu thats in it... what ecu should i get?
Old Oct 30, 2011 | 04:07 PM
The Grumpiest
Check the FAQs for how to check CELs (check engine lights). Do you actually have any?
YOu pretty much stuck a non-VTEC engine in a car that is supposed to have a VTEC engine in it. Now the VTEC ECU is looking for a VTEC engine which it doesn't see.
D15B7
Found in:
1998-2000 Honda City SX8
1992–1995 Honda Civic CX (Canadian model)
1992–1995 Honda Civic GLi (Australian model)
1992–1995 Honda Civic DX/LX
1993–1995 Honda Civic Del Sol S
1992–1995 Honda Civic LSi Coupe (European Market)
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 × 84.5 mm (3.0 × 3.33 in)
Compression : 9.2:1
Power : 102 hp (76.1 kW, 109 PS) at 5,900 rpm
Torque : 98 ft·lbf (13.5 kg/m, 133 Nm) at 5,000 rpm
Valvetrain : SOHC (4 valves per cylinder)
Cam Gear: 38 Tooth
Piston Code : PM3
Fuel Control : OBD-1 MPFI
ECU Code: P06
Head code: PM 9-6
Non Vtec
I must say I'm truly baffled. You swapped in an engine, which is not really an easy task for a "noob" but you don't know anything about CELs?
Old Oct 30, 2011 | 04:14 PM
JStroupe's Avatar
D15B7
Found in:
Compression : 9.2:1
Cam Gear: 38 Tooth
Piston Code : PM3
ECU Code: P06
Head code: PM 9-6
Non Vtec
lol wtf yeah, check engine light is on, thats it. i just havnt heard CEL before lol. and yeah, i wouldnt of put that motor in it if i had more time to look for motors. it was all i could find. and i needed it in like 2 days. so i had to do the swap in a day. so P06 is what i need?
Old Oct 30, 2011 | 04:18 PM
The Grumpiest
One for a manual. Not an automatic. Also the same OBD.
Kudos for the swap. You might also want to check the mechanical and ignition timing and do a full tuneup.
Old Oct 30, 2011 | 04:36 PM
JStroupe's Avatar
why would i do one for a manual if my car is automatic? and whats obd? sorry my noob kickin in.
Old Oct 30, 2011 | 04:49 PM
The Grumpiest
This is why you list all details about your car in the first post.
If your car is automatic then get an automatic ECU.
Old Oct 30, 2011 | 04:59 PM
JStroupe's Avatar
lol my bad. i didnt because i didnt think i needed to. a guy on craigslist has a chipped P06 ecu with 450 injectors.
Old Oct 30, 2011 | 05:03 PM
The Grumpiest
No. YOu don't need a chipped ECU with 450cc injectors unless you're putting them on a turbcharged engine.
Get a stock OBDI P06 ECU for an automatic.
Old Oct 30, 2011 | 05:09 PM
JStroupe's Avatar
okay thanks. so should that solve the problem?
Old Oct 30, 2011 | 05:24 PM
The Grumpiest
It definitely is a problem that needs to fixed.
Old Oct 30, 2011 | 05:59 PM
JStroupe's Avatar
but will it stop my car from bogging down and being so hard to start up in the morning?
Old Oct 30, 2011 | 06:06 PM
The Grumpiest
I also told you to check timing. And do a tuneup.
Old Oct 30, 2011 | 06:17 PM
JStroupe's Avatar
alright thanks. im gonna put a ecu in it with the next day or so, and ill get it tuned up and stuff.
Old Oct 30, 2011 | 06:26 PM
92lxsleeper's Avatar
you need a p06 ecu. the ex comes with a p28. make sure its a manual ecu, if you have a 5 speed.
Old Oct 30, 2011 | 10:37 PM
First.EG's Avatar
i have an auto p06 ill trade you for that p28 pm me if you're interested.
jkejke153753
Jul 26, 2011 06:39 AM
cleanEG
Oct 21, 2010 07:32 AM
Has_Potential
Oct 8, 2003 05:52 AM
