Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
2000 tl misfire on 5 cylinders/w multiple code and my tcs light stays on
Old Oct 30, 2011 | 09:47 AM
JDMforlifeOH's Avatar
Default 2000 tl misfire on 5 cylinders/w multiple code and my tcs light stays on
oky so i drove my car to work the other morning and it ran fine i started it at break that day to let the car warm up while i sat in it and i noticed it was shaking and has never done that.i turned it off and went back in, when i got out of work and started to leave my check engine light was flashing and my tcs light is staying on, it drives like crap it was horribal if i go faster than 35 does not try to die or idel weird or anything, i got home and pluged my computor into it and got codes
p0301 misfire cyl 1
p0302 misfire cyl 2
p0303 misfire cyl 3
p0304 misfire cyl 4
p0305 misfire cyl 5
p0300 random/multipule misfire
i have no idea what it could be and have read many forums on this and noone had a answer so could anyone help me out with trying to solve it that would be amamzing i just got the car and am used to d series civics lol
Old Nov 4, 2011 | 02:32 PM
civichxtreme2's Avatar
Default Re: 2000 tl misfire on 5 cylinders/w multiple code and my tcs light stays on
Sounds like it jumped timing. Have that checked and for gods sake stop driving it until you have that checked.
Old Nov 4, 2011 | 07:54 PM
spoolinfool's Avatar
Your in luck, one of your coils only took a ****. Test them by unpluging and pluging the connectors on each coil one by one .It must be done with the car running.When u pull the connector of the dead coil it will have no effect on the engine. They good coils when unplugged will cause the engine to run rougher and almost stall.The coils are 100 bucks for oem. You could also buy aftermarket at Napa for around 40ish.Those misfire codes are on because your computer is having a hard time tracking downnthe bad cylinder coil thats all
Old Nov 5, 2011 | 09:54 AM
I dont know I had a coil fail and it only showed the misfire cylinder code and the random misfire code, but hopefully thats the solution
Old Nov 13, 2011 | 08:14 AM
chienchien's Avatar
might need valves adjustment
Old Mar 17, 2012 | 11:39 AM
thankkkk youuu spoolin cuz that was deff the problem,
SiTR
Feb 14, 2008 04:19 PM
M15
20
Aug 13, 2005 12:49 PM
Teggin2
Feb 18, 2004 12:04 PM
UpstateCivic
Jun 7, 2003 12:27 PM
Blue teg
Jan 14, 2002 06:47 PM
