blower motor problem
Old Oct 30, 2011 | 07:56 AM
black0hatch's Avatar
Default blower motor problem
i know about the speeds 1 and 2 not working means its the resistor right? well on my car only speed 1 doesnt work and all the others do. also when its cold out like in the mornings the switch is real stiff like it doesnt have that click feeling in between settings so you just gota move it around till the blower goes on. then when its warm it fells like normal. any help would be great.
Old Oct 30, 2011 | 08:23 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: blower motor problem
Very high possibility your switch is gummed up/corroding. You can take your climate control apart to look at the switch - but honestly, who actually uses the lowest setting anyways?
Old Oct 30, 2011 | 09:20 AM
lazlong's Avatar
It could still be the resistor if it's only speed 1 not working.
Old Nov 4, 2011 | 02:59 PM
i think ill try the resistor first can you visually tell if its bad?
Old Nov 4, 2011 | 03:04 PM
lazlong's Avatar
Sometimes it's so bad you can see it, sometimes it isn't. Only way to know for sure is to use a multi-meter.
shuiyuan
15
Feb 24, 2015 12:01 PM
SacTownKing916
Feb 11, 2009 07:46 AM
XkjeldorX
Aug 28, 2006 09:01 AM
scoobyghost
Jul 24, 2003 09:56 AM
Sedat1ve
Dec 19, 2002 08:49 AM
