h2b will not start. searched!!
Old Oct 29, 2011 | 03:54 PM
93egboosted's Avatar
Default h2b will not start. searched!!
1996 integra gsr
obd1 jdm h22a
h23 timing tensioner setup
tried starting the car for the first time the other night, no spark figured out when i rewired the dizzy plug it was incorrect so i found another obd2-obd1 conversion chart. after using this chart ive posted up i now have spark with p28 and stock gsr injectors that i know are good, the initial start the engine fires then dies instantly and remains to only crank over. so i thought maybe ecu.... so i put my s300 out of my turbo car and uploaded a stock h22 map and same result. the car has a integra dizzy cap now i believe and people say to use a 90-93 accord... i roughly measured the inside of it where the rotor would be seems to be good
pulled the plugs black as night and smell like fuel
checked timing and its dead nuts on
any help would be appreciated
thanks
john
Old Oct 29, 2011 | 04:33 PM
93supercoupe's Avatar
Default Re: h2b will not start. searched!!
try fudging yourself
Old Oct 29, 2011 | 04:52 PM
i know where you sleep at night burt haha
Old Oct 29, 2011 | 04:53 PM
firing order 3 4
1 2
Old Oct 29, 2011 | 04:58 PM
even with the stock h22 injectors and resistor box it did the same. It seems as if the spark timing and injector timing arent synced.
Old Oct 29, 2011 | 05:46 PM
h22apwrd95's Avatar
Yeah, there is a big difference in flow between OBD1 peak and hold H22 injectors (345cc) and OBD1/2 B-series saturated injectors (240cc). If you are trying to start it on the 240cc units, it won't start.
Old Oct 30, 2011 | 04:25 AM
aight, we will throw the h22 345s back in and try again. it didnt start with those either tho.
Old Oct 30, 2011 | 07:25 AM
Possibly thought the h22 injectors were bad so i tried my gsr injectors only to start the car and nothing...
Old Oct 31, 2011 | 08:14 AM
bump
Old Oct 31, 2011 | 03:59 PM
compression checks out 255-260 on all cylinders. thinking it is dizzy related i honestly dont know, any help is greatly appreicated
kirilli4
Feb 10, 2013 06:21 PM
93egboosted
13
Nov 5, 2011 06:22 PM
Hotel121
May 9, 2011 05:30 PM
bgizzle33
Jan 31, 2009 03:21 PM
4DRPIMPIN
Feb 12, 2005 06:27 AM
