my 5 speed transmission acts like a automatic
Old Oct 29, 2011 | 08:30 AM
Mugenboij's Avatar
Default my 5 speed transmission acts like a automatic
I been having problems with this thing. If I I have it in 1st-5th when I start the car up it creeps forward and if I start it in reverse it creeps backwards. All the with out my foot on the gas. And if I tweek the like like you would do to spin the rotar on the distributor it will also jerk. And if I start it in neutral it wont go into gear, I have to play around with it for a minute before it will even budge. When the car is off all gears go in smooth. And another thing the car will stall out after it warms up for like 30 mins.
Old Oct 29, 2011 | 08:40 AM
godslayer's Avatar
Default Re: my 5 speed transmission acts like a automatic
Fix your clutch/hydraulic system.
Old Oct 29, 2011 | 10:21 AM
Hawkze_2.3's Avatar
It creeps when you have the clutch pedal pushed in?
Old Oct 29, 2011 | 01:03 PM
Mugenboij's Avatar
Yes
Old Oct 29, 2011 | 01:27 PM
AWDManiac's Avatar
clutch slave cylinder, clutch master cylinder, and lastly it could be the throw out bearing. Somehow the clutch is getting friction to the flywheel causing it to do that when started. The throw out bearing could be stuck in a position too. If its failing, you will have all the problems you are describing. Sorry to bring bad news but I've had the throw out bearing go out in my vehicles. Also might as well replace the clutch and have the flywheel surfaced or replaced while you're at it.
Old Oct 29, 2011 | 11:07 PM
Mugenboij's Avatar
I just replaced the transmission I thought that the clutch went out but I jut had no fluid in the transmission. So I probably bled the system wrong.
Old Oct 30, 2011 | 10:58 AM
Hidenplanvew's Avatar
not enuff pressure in the clutch sytem or pressure plate has gone bad
Old Oct 30, 2011 | 06:11 PM
Freak of nature's Avatar
Definitely a clutch problem....
Old Oct 30, 2011 | 09:57 PM
Brandon92's Avatar
it was your clutch slave cylinder on the front of the tranny i had the same problem with my 95 integra
Old Oct 31, 2011 | 12:22 AM
maximumm's Avatar
Also sounds like a clutch prob to me
Old Oct 31, 2011 | 06:19 AM
typemismatch's Avatar
Honda owns me
If you're not leaking fluid, bleed the clutch, if you are, either rebuild or replace the master/slave and bleed the clutch.
Also, bleeding a clutch isn't the same as bleeding brakes.
Old Oct 31, 2011 | 12:56 PM
kozanatos's Avatar
Brake the bleeder screw, slowly pump the clutch until no bubbles?
Old Oct 31, 2011 | 04:06 PM
how is bleeding a clutch not like the brakes? Its the same process, but the best way is to pressure bleed it with a BG machine... but bleeding it is a start
Old Oct 31, 2011 | 05:13 PM
Honda owns me
Because you don't "pump it up" and let the pressure out, you pump it through with the bleeder open on the down and closed on the up.
Old Nov 1, 2011 | 04:13 AM
1GPlusSH's Avatar
clutch...don't fix it. do an automatic conversion
Old Nov 1, 2011 | 03:51 PM
Mugenboij's Avatar
How much do you think a shop would charge to have it done by machine?.....I did it my self and it took me like a hour going back and forth. One big major pain
Old Nov 1, 2011 | 09:05 PM
nus_dogg's Avatar
Sounds like clutch isn't disengaging?
Old Nov 2, 2011 | 06:13 AM
Honda owns me
Another trick is to run a vacuum line from the bleeder to a pop bottle partially full of fluid to keep the bleeder from sucking air.
Old Nov 5, 2011 | 04:47 AM
ShoofIsLudin's Avatar
have you adjusted the clutch pedal push rod??????
not once in this thread is adjustment even mentioned....
There's a 12mm nut on the back side of the rod, against the clutch pedal bracket. It sounds like you don't have enough pedal travel to cleanly get the clutch to engage and go into gear when the engine is spinning.
In that case....u essentially have to adjust the rod to simulate being longer, so you'd screw the rod OUT/AWAY for the pedal, snug the lock nut, and see if it gets any better.
PERSONALLY, i use a 12mm line wrench on the nut, and a pair of pliers to rotate the pushrod. And you don't have to gorilla torque it to lock it...just a quick snug (at least until you get the adjustment right)
Old Nov 5, 2011 | 06:46 AM
Mugenboij's Avatar
Thanks ill try that out
Old Dec 5, 2011 | 09:17 PM
JDMequalslife's Avatar
Just fixed the same problem on my friends prelude, its the clutch master cylinder. when we bleed it, it was black haha. Just replace the clutch master cylinder
Always262
Transmission & Drivetrain
Jun 25, 2017 07:16 PM
Matt Royer Jr.
Mar 25, 2013 11:15 AM
MugenGTR
Jan 29, 2012 02:14 PM
93sivtec
Jan 20, 2008 03:16 PM
