researched problem with cluster back light and dashboard lights
Old Oct 28, 2011 | 05:46 PM
cleanda6's Avatar
Icon6 researched problem with cluster back light and dashboard lights
1990 civic lx 4 dr ... as stated above i researched this and even looked at the schematic for the back lights to cluster and other components on dash.... im wondering if anyone else had this problem .. i checked the #8 fuse on fuse box followed the wires to the cluster and no use.. head lights work ac works hazards work but no back lights on anything on the dash board .... any help would be greatfull
Old Oct 28, 2011 | 07:40 PM
all-motor-crx's Avatar
Default Re: researched problem with cluster back light and dashboard lights
this happened to my crx and it ended up being a fuse, fuse 8, ended up being a 15a in there instead of a 10. but re check your wires and pull the sockets out and see if its corroted any, possibly a short somewhere
check this
https://honda-tech.com/forums/honda-accord-1990-2002-2/dash-tail-lights-fuse-keep-blowing-5th-gen-2159332/
Old Oct 28, 2011 | 07:49 PM
check this out and go down to the tail lights part, it may or may not help
http://accutach.com/Documents/88CRX-...xAnatomyR1.pdf
Old Oct 29, 2011 | 01:58 PM
cleanda6's Avatar
thanks ill check i think i have a 20a fuse in their i will change it to a 10a
Old Oct 29, 2011 | 02:31 PM
4drEF's Avatar
Keyboard Humorist
if the fuse isn't blown then it's going to work.
if it's a larger number than what is supposed to be there just makes you run the risk of frying up wiring and causing a fire if there is ever a short.
Old Oct 29, 2011 | 08:22 PM
BiGZ's Avatar
DoeZ the dimmer switch do anything? (muh 88 has lil round **** + controlZ all backlighted dash lights,dark one all the way one way + all bright full the other way) Ifthat'Z not it,check if voltage present there @ cluster dimmer sw)
Old Oct 29, 2011 | 08:40 PM
tonylovesjdmEF9's Avatar
hahaha crazy stuff i jjust had this happen to my today in the morning when i was going to work but anyways bro i thinkyour fuse box is bad get a multimeter check for voltage on the fuse pins when you flip the lights on and check for continuity if you have continuity you have a short for sure or the fuse box is shorted out if there is voltage but no continuity it could be that the inside of the fuse box is done fried out or just worn out and you should just replace it
Old Oct 29, 2011 | 09:07 PM
cleanda6's Avatar
thanks everyone for the reply i lookedbehind the stereo and thier it was a bunch of wires cut and just stuffed behind the radio found the red/black wires cut in two just soldered together and it worked im happy ... i hate when people just do things half *** ... thier is another problem though when the switch is on all the way without turning the car on the shifter can be moved and when the car is on i cant move it form parking ? i tested the voltage it seems to be 12vdc on both wires when the car is on any ideas where to start?
Old Oct 29, 2011 | 09:08 PM
cleanda6's Avatar
help with my other problem also https://honda-tech.com/forums/showth...4#post46260244
hj2
Sep 9, 2009 07:18 AM
vtecstacy21
Nov 16, 2007 11:05 AM
1sikcoupe
10
May 7, 2004 03:23 PM
mrbsponge
Dec 31, 2003 03:31 PM
smeister
May 24, 2002 04:09 PM
