H22a in a 97 honda accord clutch trouble PLEASE HELP!!
I have a 97 Honda accord that used to have an automatic tranny I did the h22a swap and converted it to 5-speed but I put 3 new clutch kits in with pressure plate flywheel throw out baring and it only last about 2days and I know how to a 5-speed and I don't ride the clutch or nun so I wondering why it's burning up so fast
Youve replaced the clutch 3 times in a week?
Sounds like its not fully disengaging, does the car feel.even slower then an accord usually feels?
Yes lol 3 times this week I know it sounds crazy but its Tru And it crazy faster than the stock motor I know its a hydraulic clutch but is there any way to adjust it?
are you using clutches made of camel **** or something? i would really like to know what clutch is in there, and what it looks like when it comes out...
yea u need to get a exedy clutch and check flywheel surface as well as rebleeding clutch. then if that doesnt fix it ur not installing them right. make sure ur using the alignment tool for the clutch disc
Its a act clutch it look brittle when it comes out and the pressure plate looks like its blueish purpleish as if it waz heated with a torch
I bled the clutch 4 times per clutch and I used the alignment tool with the brand new flywheel. Where did you get you exedy stage 1 clutch
