Where to find turbo manifolds??
Old Oct 28, 2011 | 08:41 AM
MalcolmV8's Avatar
Default Where to find turbo manifolds??
Hey Guys,
Been looking around for a turbo manifold for a D series motor for a while. What are some good sources?
For example I've heard Turbonetics makes some but I can't find any on their website. I want to see pics before blindly purchasing.
I also hear a lot about SFP but not sure what that is. I googled and it seems to be South Florida Performance but can't find a website for them. I did see in one members sig on the forum www.sfp.net but it doesn't work.
Anyhow I don't mind if it's a full length or log really as long as it works well and I can keep my A/C.
I've searched ebay till I can't see straight and all their log manifolds have the waste gate on a single cylinder for D series motors and I hear that's a big no no so I'm avoiding those.
I've also heard the ebay long tubes (like ram horns etc.) are garbage so I avoid those too. Also the ebay full length ones don't allow you to keep a/c.
There's gotta be some good sources, websites etc. with pics where I can find something that will work for me and get it.
So what's all the good locations you guys use?
Thanks
Malcolm
Old Oct 28, 2011 | 08:44 AM
Spoolinls's Avatar
Default Re: Where to find turbo manifolds??
look for ctd fab he just built me a ac friendly top mount does really good work and prices r really good to
Casey's Avatar
www.go-autoworks-store.com
Old Oct 28, 2011 | 09:29 AM
MalcolmV8's Avatar
Originally Posted by Casey
I like what I see so far. Here's the civic D series log they have
http://www.go-autoworks-store.com/gocairtuma.html
It looks like the turbo is off set a little to the passenger's side so the down pipe will clear the a/c compressor. I've emailed them and asked for more pics. At only $125 too it fits the budget well.
Old Oct 28, 2011 | 10:41 AM
Fnix's Avatar
www.spoolinperformance.com
Old Oct 28, 2011 | 10:54 AM
MalcolmV8's Avatar
Originally Posted by Fnix
Already have one of those long tubes. It's in my build thread. The quick 4AC. I bought it used and while it looks like a good quality piece it doesn't fit my car. I contacted SP and they said I needed a different turbo. So I purchased the turbo they said and $650 later still no fit. Looking for alternatives.
They did offer to make me another manifold at a discounted price but they are still so expensive I'm looking for alternatives.
Old Oct 28, 2011 | 11:24 AM
osc007's Avatar
http://www.bisimoto.com/
They might not have AC comp units, but I'm not sure.
http://www.lhtperformance.net/
This is the only shop I let touch my car, they have some of the best fab work and countless cars that appear on honda tuning.
Old Oct 28, 2011 | 12:46 PM
TheShodan's Avatar
Moderator
You should have just done the log manifold, for unobstructed fitment. It "fits", but like we've discussed, you have to do a bit of reconfiguring. I guess "Fitment" is the wrong word.
The only others that are great are go-autowerks, spoolin performance (log), and rc-autowerks.
Get the "log" manifold for this, ok? keep it simple, and you do less "configuring". You'll make whatever power that little d-series can kick out with the log. No equal-length, or "shorty" manifolds are needed.
Old Nov 3, 2011 | 06:15 PM
MalcolmV8's Avatar
Well this sucks. I'm in for 3 manifolds, 2 turbos, 2 clutch slaves and NOTHING fits.
My latest is Go Autoworks log with the Precision 5431. I even called them and confirmed this would fit before purchasing.
Is there an aftermarket slave or some other alternative that I can use to get some clearance?
It just amazes me how these manifolds "made for D series" place the turbo in such horrible locations.
Old Nov 3, 2011 | 08:33 PM
mighty137's Avatar
If budget is not a factor........FULL-RACE!! http://www.full-race.com/store/turbo...-manifold.html
Your turbo will be facing the cooler side and plenty of clearance !!
Old Nov 3, 2011 | 08:36 PM
Turbo-LS's Avatar
Thats a simple fix if its your only issue. get a 90 degree fitting and replace that line with stainless draided teflon hose, FIXED !
you wont be able to put a filter right on the turbo you wil have to put tubing extension to a place where there is more room
Old Nov 4, 2011 | 05:14 AM
MalcolmV8's Avatar
It's does not work with a/c and that one is hella expensive lol.
Interesting. When can I find such parts? the 90 degree fitting that will go in there and hose with the correct ends etc. Any links? That may work if I can find the parts.
Another option I'm thinking of is this other tubular log go autoworks has. It places the turbo higher than the cast manifold I got. I've emailed them to see if it will work better for me.
http://www.go-autoworks-store.com/go...-manifold.html
Thanks
Old Nov 4, 2011 | 05:29 AM
Turbo-LS's Avatar
summitracing sells just about every part you can think of. I think someone on here even offers that replacement line as a kt, try B&R fittings
Old Nov 4, 2011 | 06:24 AM
TheShodan's Avatar
Moderator
Thanks
This is the manifold I was originally stating to use from Go-autowerks. Their sch10 log manifold, not the cast crap.
As for the 90 degree coupler for a turbocharger inlet, measure the OD of the inlet and the OD of your filter. Then go to http://www.frozenboost.com to find the right coupler. They even have T-bolt clamps to use.
Old Nov 4, 2011 | 06:45 AM
LightningTeg's Avatar
Community Builder
Im not sure what that thread is going into the slave but a simple -3an line to 90deg male to male fitting would solve your problems there
Old Nov 4, 2011 | 12:07 PM
Turbo-LS's Avatar
You can't run regular brained lines lightning it needs to be a teflon brake
Line. It's a 10mm x 1.0 or 1.25 pitch and inverted or reverse flare
Old Nov 4, 2011 | 12:44 PM
MalcolmV8's Avatar
Ah ok I missed that. I went ahead and ordered that manifold this morning. Hopefully it gets here early next week and I hope to heck it works lol.
Yeah that "might" work. Space is so tight I think that 90 degree piece will stick up in the way of where a pipe needs to go. I've ordered their tubular manifold too. If that doesn't work I'll revisit this idea.
Thanks for the specs. Is that the same as NTP threads are is a inverted/reverse flare something else?
Old Nov 26, 2011 | 05:13 PM
MalcolmV8's Avatar
Well my go-autoworks tubular log finally arrived. Took over 3 weeks to get it, wtf.
Anyways it's the one on the very right. Yes my forth manifold I'm trying now.
Unfreaking believably it has clearance issues with the clutch slave too. sheesh I give up lol. This one has the least amount of interference though and I think I can make it work.
Old Nov 26, 2011 | 05:25 PM
EsotericImage's Avatar
Retired Moderator
One bad thing about the log mani is that its restrictive past 6k..
Old Nov 26, 2011 | 05:28 PM
MalcolmV8's Avatar
Oh well. That sucks but for now it'll do to get this car running. Like I said this is my 4th manifold and it's getting really frustrating to get something that fits. I'm just amazed at how many manifolds are sold out there as "made for civic" of my model year and they each look nothing alike and all don't fit one way or another.
Old Nov 26, 2011 | 07:43 PM
Retired Moderator
lose the AC and youll free up alot more room. till then, your stuck with a tight squeeze
Old Nov 26, 2011 | 08:35 PM
TheShodan's Avatar
Moderator
Too general of a statement. I wouldn't say that until it is shown from his particular setup,.. really.
Old Nov 26, 2011 | 08:37 PM
TheShodan's Avatar
Moderator
Like I've said to you time and time again, they are compatible with these engines, but it doesn't mean they are going to clear everything without adjustment or acceptance that some things will be a tight fit.. Its like that with many of the B-series too. Many of us enthusiasts are just used to the requirement of a bit of adjustments..
My condolences for your frustration, however, It is, what it is.. welcome to the world of imports.
Old Nov 26, 2011 | 09:10 PM
MalcolmV8's Avatar
Lol yeah I'm hopefully on the way now. I'm starting to make some progress so that's always exciting.
scspeed
Mar 8, 2009 11:56 AM
k4rts
Aug 3, 2006 06:31 PM
94integragsr
Sep 22, 2005 10:43 PM
Acura_I-RS
Feb 21, 2005 04:13 PM
typeRSXS
Mar 22, 2004 01:34 AM
