Can you put 15" rims on a 2008 Civic LX?
Old Oct 27, 2011 | 06:18 PM
Baffle's Avatar
Default Can you put 15" rims on a 2008 Civic LX?
Ok so I know stock size is for a 2008 Civic LX is 16/17.
I see though that the 08 Civix DX was 15" (195-65-15).
Just curious, as I have some 15" 5x114.3 prelude rims with Winter Tires from a friend if I want, would save me buying a winter set.
Old Oct 27, 2011 | 06:28 PM
toyomatt84's Avatar
Sanji
Default Re: Can you put 15" rims on a 2008 Civic LX?
You should be able to, as long as the spokes have enough clearance to the caliper. I'm not entirely certain on that combination, exactly. Have you tried test-fitting them? The fronts will be the bigger caliper to contend with, so if they clear up front you should be fine.
Old Oct 28, 2011 | 05:21 PM
Baffle's Avatar
ok thanks, i'll check the clearance
Old Oct 30, 2011 | 10:22 AM
Baffle's Avatar
Yeah so I am not a technical guy at all... I called a local tire shop to discuss my options for winter tires and rims. They actually suggested going to a 195/65/15, said they do it all the time. And they said requires no adjustment to any components.
According to the tire size calculator, speedo difference is marginal.
For the price I will try it out, a guy at work has a set of gently used Semperit Speedgrips on 15" Honda fitted steelies for $200. I'll see how it goes.
Old Nov 2, 2011 | 12:47 PM
doc@tirerack's Avatar
Yep, we use both 195/65R15 and 205/60R15 for snow tires on the car with zero issues.
SpecRawr
Jul 23, 2010 09:14 AM
Mansoor
Honda Civic (2006 - 2015)
Jan 2, 2009 07:36 AM
hellshock2182
Apr 30, 2005 01:36 PM
DSRxSALSA
Apr 11, 2005 08:51 AM
Accrod98
May 1, 2003 05:35 PM
