Quick ? about OBD 1 car with OBD 2 Motor
Old Oct 27, 2011 | 05:43 PM
LSej1's Avatar
Default Quick ? about OBD 1 car with OBD 2 Motor
I am searched this topic and i am only posting this to confirm what i have read....
I have an OBD 1 Ej1 1994.....i am putting a OBD 2 LS swap from H motors in it...I can use the OBD 2 motor harness and i need a OBD 1 ECU correct?
Old Oct 27, 2011 | 08:32 PM
egsleepercivic's Avatar
Default Re: Quick ? about OBD 1 car with OBD 2 Motor
if the LS swap is jdm the harness will not work, you can get a usdm odb2 harness and it should be plug and play
Old Oct 28, 2011 | 04:39 PM
LSej1's Avatar
yeah i know i ran into this problem with the JDM harness last time i got a motor from hmotors
Old Oct 28, 2011 | 06:32 PM
alextrox69's Avatar
use the harness from ur ej1 it will work just wire the distributer to work with obd2 and do the same with the alternator. works great for me just make sure u soulder it good
Old Feb 26, 2012 | 12:45 AM
LSej1's Avatar
Can't use my original usdm harness...it went through a flood. I don't want my plugs to corrode and stuff
Old Feb 26, 2012 | 02:48 AM
portenio78's Avatar
Get a OBD2 harness and everything will plug into your civic's harness.
Gravy
Sep 3, 2007 06:11 PM
HATCHingMN
14
Apr 4, 2007 01:33 PM
vtec25
Oct 31, 2006 10:38 AM
TIRENECK
May 11, 2004 04:29 PM
guyuenvy
May 16, 2002 12:27 AM
