Driver side making a ringing noise from wheel
Old Oct 26, 2011 | 09:17 PM
Pwnmeister's Avatar
Default Driver side making a ringing/squeaking noise from wheel [SOLVED]
I drive a 96 Civic CX.
So yesterday i lowered my car some more, maybe by an inch (coil over sleeves) and installed short shifter with new bushing.
After that, I hear a ringing sound from the driver side front wheel whenever I'm driving. Even when i jerk my steering wheel to the left like half an inch. It's a very sharp ring sound, imagine tapping two glass bottles against each other. That's basically how it sounds. (ding ding ding)
I push down on the hood by the fender on the driver side, and it makes the same ringing sound. So what could it be?
I'm quite sure everything was tighten after adjusting my car height but I'll check again.
This ringing sound was never there before
NOTE: the sound occurs even when my car is off and parked
EDIT: (11/30/11)
Just for future references, I went ahead and got my driver side CV halfshaft replaced since the boot was torned. The sound went away after.
Old Oct 26, 2011 | 10:28 PM
Pwnmeister's Avatar
Default Re: Driver side making a ringing noise from wheel
Anyone?
Need more details?
Old Oct 27, 2011 | 04:37 AM
grumblemarc's Avatar
The Grumpiest
Climb under the car and check.
Old Oct 27, 2011 | 07:42 AM
sde780's Avatar
Jack the car up and check. Could be a lot of things - maybe you bent the dust shield? Did you install the coilover sleeves properly?
Take pics and post them up.
Old Oct 27, 2011 | 10:02 AM
Pwnmeister's Avatar
Ya I'll check under.
And I installed the sleeves for like 2 months now. I just lowered the height a bit more the other day.
Old Oct 27, 2011 | 11:25 PM
Pwnmeister's Avatar
Is there a list of things I should be checking when I'm under the car?
Like bushings, LCA, and whatnots
Old Oct 27, 2011 | 11:38 PM
kozanatos's Avatar
Wheel Burring
Check for playyyyyyyyor just replace it.
you can do it yourself sir, and bring it to a shop to press in the new burringz
Old Nov 5, 2011 | 04:57 PM
Pwnmeister's Avatar
Well I finally jacked up the left side of the car and see if anything is loose. Nothing was loose. I did find that my left side CV boot is ripped. Not too sure if that's the reason but I wouldn't think so since the sound has only been happening after I lowered my car some more.
I even turned the wheels while the car was up, no sound. The sound occurred once I let the car back down with the wheel on.
I totally forgot to check if my wheel was rubbing against something though
Old Nov 5, 2011 | 09:50 PM
strategy400's Avatar
try carefully jacking the car from under the suspension/lca/balljoint area so weight is on the suspension just enough so the wheel is 1 inch off the ground and spin the wheel by hand.
Old Nov 5, 2011 | 10:59 PM
Pwnmeister's Avatar
hmm okay I'll try that
Old Nov 6, 2011 | 07:07 AM
sde780's Avatar
Mine was making a scraping/ringing sound after I took off my knuckle yesterday - the brake dust shield was touching the rotor slightly.
Old Nov 6, 2011 | 10:56 AM
Pwnmeister's Avatar
Ya, I was hoping mine was dust shield too because that would be easy to deal with. But it wasn't, I even pushed it away from the rotor
Longchamp
Oct 19, 2014 01:48 AM
DsevenEm2
Honda Civic (2001 - 2005)
Oct 13, 2007 12:04 AM
MATiC
Feb 23, 2007 05:13 PM
zrx168
Dec 4, 2001 12:13 PM
KRNewbie
Nov 24, 2001 04:39 PM
