FS: del sol parts and car stereo stuff other electronics
Old Oct 26, 2011 | 02:31 PM
raverx3m's Avatar
Default FS: del sol parts and car stereo stuff other electronics
im located in lynnwood. local pickups only
DUE TO MANY FLAKERS I WILL NOT meet up or drive anywhere, all parts can be picked up from alderwood mall,\parts are used(and functional when taken off the car) sold as is, its your responsibility to inspect them!!!
i can meet you at fry's electronics in renton if im there buying some computer parts. or up north in mt vernon if im visiting my parents.
Please TXT me on this number 360-510-six 69 eit ( i dont pick up numbers that i dont know so dont waste your time calling please)
check out my CL ad for more stuff
---------------------ELECTRONICS-----------------------
blackberry bold 9700 smartphone used for 3 weeks before i upgraded 150( comes with everything and the box) prefer trade for any of the parts listed in trade section
HTC HD2 used for almost 2 years so theres some wear on it but it has not given me any problems its running the latest android build for TMOBILE and is stable.
also comes with everything and new charger. 120 for that one
the phones are not pictured.
sony xm-1252gtr 2 channel/mono bridgeable amp 80
netgear wireless router( extra one frommy parents)
great lil router ive been using this model for last 8-9 years and bought 3 already with 0 problems.30 dollars
infinity reference 4 inch coax speakers in great shape tested and working 40 dollars
OEM jbl multichannel amp 30 dollars
powers, front woofers and tweeters crossed over at the amp, rear 6x9 and has 2 subwoofer outputs to power 2 subs or one DVC sub.
great for a stock system upgrade without adding aftermarket 4 channel.
2005 mercedes c320 stock stereo system complete (headunit, cd changer speakers subwoofer and amp ( its the harman kardon system) 400 for all
alluminum cone high quality mids and tweeters.
intel P4 cpu 3ghz. i upgraded to newer one 40 dollars for this one comes with stock fan that never been used.
------------------DEL SOL PARTS----------------------
d16y7 d16y8 d16z6 valve cover gasket 10 dollars( honda mislabeled it as dohc gasket and wouldnt ship a new one untill i return this one)
red stripe del sol seats 100 dollars rips on driver seat typical, pass side os great condition
del sol muffler ebay but sounds decent 2.25 flange to 3 inch at the muffler 40 dollars (used for less than a week)
valve cover d16y7/y8 40 dollars anodized orange with clear coat
ITR LSD diff. just the LSD no bearings or gear 250. it is inspected and looks good i can take it apart for you to look at also
94 DC integra front knuckles with hubs and axles+ shock fork 140 for the set
brake upgrade for civics and del sols with smaller brakes(del sol s and del sol SI)
15/16 brake master cylinder very clean no leaks 40 dollars with reservoir
crossmember support bar from 94 integra 10 dollars
B series del sol shift linkage with jdm shifter 120 (you need this for b series swap you can only use del sol b series linkage in del sol)
del sol carpet in good condition no rips or tears just needs vacuuming 30 dollars
fuel sending unit with low fuel sensor (from 94 del sol SI) 20 dollars
del sol battery tray with tie down 10 dollars
del sol windshield washer reservoir 10 dollars
2 complete vizor and a pillar sets( vizors a pillars and vizor panel) 50 per set
1 extra set of a pillars with a hole for gauge mounting on driver side 20 dollars
94-97 del sol glove box with few scratches but no broken tabs 20
del sol tail lights ALL RED painted. 50 for both( will have the picture soon)
del sol rear window upper seal 10 dollars no overspray
del sol rear speaker panels and middle panel 40
rear storage compartments with side covers 40
dome light panel with dome light 20
autotechnik glow gauges missing dimer switch 30
DEL SOL VTEC gauge cluster 150 firm
del sol S cluster 50
1 usdm cluster switch panel 50
one jdm cluster switch panel 50
COMPLETE rear window assembly with glass 100 tested and working( i will test it in front of you)
del sol targa top holder with shocks and brackets 30
del sol trunk lid with shocks and brackets 60 firm ( original white paint in good condition)
del sol rear licence plate panel in good condition 30
COMPLETE 1993 del sol dash( the one without pass air bag) the vin number panel is detachable so you can keep your vin tag matching your car. 100 firm
(cluster, all heatvents underdash and glove box are there)
rear window outside trim( center and sides with 3rd brake light) original white paint 80 for set
side trim plastics no middle piece or brake light 20 dollars
not pictured front support beam straight not bent or damaged 60 dollars
full size integra radiator with both fans and hoses 60(not pictured its a radiator radiator)
TRADES:TRADES:TRADES:TRADES:TRADES:TRADES:TRADES:T RADES:TRADES:TRADES:TRADES:TRADES:TRADES:TRADES:TR ADES:TRADES:TRADES:TRADES:TRADES:
TRADES:TRADES:
konig retracks or rota track-R 16 or 15 inch with tires please( not bold tires)
half size dual core radiator alluminum
kenwood kiv-701,kiv-901
ctr,ITR cams, itr red valve cover in good condition
milano red not faded trunk and hood for del sol
del sol door panels with no creases.
some good headers for hi comp gsr
2.25 inch exhaust midpipe for my ITR muffler.
carbon fiber hood or trunk
SMALL LAPTOP i need one for sound tuning.
ELECTRONICS
DEL SOL PARTS
Old Oct 27, 2011 | 08:03 PM
raverx3m's Avatar
Default Re: FS: del sol parts and car stereo stuff other electronics
UPDATE
2 sets of del sol red stripe seats both on same condition
both driver seats are torn( one has a good bottom cushion but torn back other got both torn)
both pass side seats are great condition.
300 for both 150 each
or 200 for better set and 100 for other one
if you buy more stuff i will give better deals. but dont expect too much, i need money too.
AEBS "whirlwind" intake manifold that makes the whistle when you hit certain rpm
intake manifold 120
complete throttle body with gasket 50
temp sensor1.99
IACV and the other lil sensor on the back 30
also an OBD2 fuel rail with injectors and stock fpr. 50
if you want to buy separate parts.
all together 200 i think is a fair price for a complete manifold with everything working.
i just replaced it with stock ITR manifold 2 days ago.
selling cuz i need money otherwise id keep it for supercharger
the bolts are just hand tightened to show that everything is there.
Old Oct 29, 2011 | 05:32 AM
NUMISMATICS's Avatar
I texted you about 4 times. No reply. I want that CD player.
Old Oct 29, 2011 | 07:29 PM
raverx3m's Avatar
alpine stereo sold
Old Nov 2, 2011 | 11:13 PM
raverx3m's Avatar
bump
i need 14 or 15 inch wheels for winter driving
just wheels
or if you have winter tires mounted on them even better ill take them too
PM me offers as long as they are not ridiculous ones.
i have a set of 13 steelies with ok tires i can throw in if you need some temporary wheels.
RSX OR S2000 seats are also welcome trades.
or some clean del sol red stripe with no tears on driver side
hondata or neptune plus cash on my side
Old Nov 9, 2011 | 08:06 PM
raverx3m's Avatar
bump update AEBS(professional products) intake manifold
second post pictures
Old Nov 17, 2011 | 08:16 PM
raverx3m's Avatar
axles sold. still have hubs if anyone wants. 50 for both. good bearings.
160 for 1994 gsr intake manifold and obd2 fuel rail. gsr obd1 dizzy.
nobody is oldschool enough to rock aebs intake manifold ?
Old Nov 20, 2011 | 01:37 PM
spoolin_eg's Avatar
PM sent, check your messages!
Old Nov 20, 2011 | 02:04 PM
raverx3m's Avatar
pm replied lol.
i need one gsr blade without tire. or two blades with matching tires(proxis 4 preferebly)
in good condition no curbs and no clear peeling.
will trade for parts listed here
Old Nov 22, 2011 | 04:42 PM
raverx3m's Avatar
BUMPED my del sol into a truck few days ago.
need driver fender, driver door, ill take both doors if you have, just the panels are on no glass.
and one GSR BLADE.
set of good coilovers. adjustable shocks
trade for parts i have
Old Dec 18, 2011 | 05:07 PM
raverx3m's Avatar
also selling my old kenwood
KDC-x891 top of the line kenwood unit, great sound goto crutchfield to see full specs.
tonns of features and flawless USB interface better than alpine cda-117.
everything works i will demo it to you before you buy so theres no questions.
comes with mounting cage, wire harness, trim ring and remote,no box.
160$ picked up
Old Dec 27, 2011 | 07:21 PM
raverx3m's Avatar
bumpy
ccarey
Jan 30, 2012 06:57 AM
Fiero
Jun 9, 2008 08:41 PM
DelSolSi93
May 2, 2005 01:33 AM
DeDonDeRosa
Jan 14, 2005 04:18 PM
