lsvtec problems
Old Oct 26, 2011 | 01:53 PM
b20vteclsintegra's Avatar
Default lsvtec problems
Im having problems with my lsvtec motor. Ok so I know I should not be running ls throttle cable and bracket and throttle body but I am for right now. The car is in safe mode right now its a 95 integra the 2 codes that come up are 5 and 7 witch are tps and map sensors. Now I was wondering is this because im running a ls throttle body and not a gsr one like I should be or does this mean that the sensors them self are bad??? Someone please help me out
Thanks
Old Oct 27, 2011 | 05:24 AM
kyden's Avatar
Default Re: lsvtec problems
there's no reason you can't run an ls throttle body. you probably have the plugs switched, since they have the same style connector.
Old Oct 27, 2011 | 11:33 AM
I dont tho I checked that. I switched them and the car dies.
b20vteclsintegra
Oct 30, 2011 04:14 PM
todaV-TecEF8
Mar 24, 2009 01:53 PM
