No power in car, except brake lights ! :/
Old Oct 26, 2011 | 08:33 AM
h22aCD's Avatar
Default No power in car, except brake lights ! :/
I drive a 94 honda accord with a h22a.
I was driving my car the other day, went shopping for about 30mins came back and tried to start it but the power started to drain out every time I tried to turn it on and then come back when I stopped trying to crank it. Somebody offered me a boost, but they switched the cables around in the middle of the boost -_-. The cables sparked up and then all the power drained completely. I tried changing all the fuses in the fuse boxes under the hood and inside the cabin by the driver side. What should I do next?
Old Oct 26, 2011 | 10:03 AM
accordmatt's Avatar
Default Re: No power in car, except brake lights ! :/
test and replace alternator. probally is dead which wont allow ur battery to charge.
Old Oct 26, 2011 | 05:03 PM
Lost Again's Avatar
Really matt....
OP-test the main fuses in the under hood fuse panel, the ones with clear tops...80 amp I think?
Old Oct 26, 2011 | 05:37 PM
redbull-1's Avatar
Yep. Usually, it's the battery fuse that blows when the cables are switched during a jump.
To replace that fuse, you use a philips screwdriver. I would disconnect the battery cables first. You don't want to accidentally bridge the connections with the screwdriver.
Old Oct 30, 2011 | 11:39 PM
h22aCD's Avatar
There was no fuse for the battery, just a severed wire. The power is back, but the battery light is on now. I figure that's the alternator gone bad?
drlagares
May 10, 2016 02:29 PM
gceniceros209
Feb 6, 2013 04:44 PM
Dave1821
Apr 18, 2009 11:27 AM
