Switching obd1 ecu to obd2 for emissions
You need to find a obd2 p72 ecu. What year is you wiring harness? you will need to match that up to for example obd2a harness with an obd2a ecu, obd2b harness with an obd2b ecu. They use different locations of the plugs.
or he can get a OBD2A to OBD2B or vice versa conversion harness
Correct me if I'm wrong but don't the 99-00 ECUs use an immobilizer? So using the 96-98 P72 ECU might be a better option. Also I believe the OBD2 JDM ECUs although not having the immobilizer won't pass emissions.
http://ff-squad.com/ecu2/?page_id=76
i dont think jdm ecu's will pass emissions, you might also have to hook up knock sensor , both o2 sensor and have a cat in place inorder to pass emission with a usdm ecu in place
http://www.hamotorsports.com/immobil...l-service.html
