CA Fs/Ft Ef Sedan Dx Clean cleaannn
Lets start off from the ground up!Suspension/wheels:
Dumped on drag dr-21 wheels (rattle canned black with polished lip)
The tires are shot!
Coilover sleeves front and rear ( doesnt ride too bad)
Exterior: original white shiny paint!!! (very minor dings here and there) considering its age!
Satin black front and rear bumpers.
Front and rear jdm window visors.
Medium dark tint front and rear ( rear windshield is super limo) lets not forget its got a pretty comfy rear seat !!!!!
Jdm goodies: Black Datum-1 tow hook (rear only)
8000k Hid headlights
Nokya yellow high beams
Yellow fog lights
2 inch Tachometer (its not ghetto because dx dont have rpms lol)
Skunk 2 (half pound shift ****) connected to a hasport short shifter.
Jdm dash cover (black)
Interior: Blue
Black carpets front and rear.
No cracks on dash
1996 dc-2 center console with cupholders! (missing shifter boot)
Pioneer head unit (ipod ready)
Clarion door speakers (front)
Custom 6 1/2 speakers in the rear By third brake light!
Needs shampoo
Powerplant: 1995 B18b1
Arp head studs
Nippon piston rings
Acl standard bearings all around
New water pump
New timing belt
New oil pump
Head has been
Hot tanked
Resurfaced (5 thousands of an inch)
New valve stem seals
Fresh valve adjustment
Hondata plastic intake manifold gasket (for heat )
Cold air intake (knock off)
2 1/2 inch megan racing High Flow Cat
Chased down by 2 1/2 straight pipe
To a 2 1/2 inlet/ outlet muffler
B20 headers (oem)
Hondata shift linkage
Drop billet motor mounts.
New upper/lower radiator hose
Honda genuine tranny fluid
New axles Da driver side/Dc-2 passenger side
1993 integra gsr throttle cable
Obd-0 b16 distributor
New distributor cap and rotor
New ngk spark plugs
New spark plug wires
Alignment was done last week! (Perfect except for camber)
1989 crx si Ecu (stock base map) Also have a 1989 crx si ecu (2 step launch @3000 rpms,Check engine shift light at 7800,redline at 8000 rpms)
Looking To trade.
Or $3500
714-605 3713
<a href="http://bit.ly/rEeIW7" target="_blank" />Check out this image!</a>
<a href="http://bit.ly/tD24oD" target="_blank" />Check out this image!</a>
fourthaxis
Oct 25, 2007 07:54 AM
come on guys 200 views and 6 replies!
