92 accord engine swap (vtech)
Old Oct 25, 2011 | 01:06 PM
K1llaturtl3's Avatar
Default 92 accord engine swap (vtec)
So I changed my head gasket and decided to have my head cleaned. Well come to find out I had a small crack in the head. So I found a nice f22b1 on Craig's List for $200. So long story short I swapped the engines.
Here are step by step pics and problems I encountered.
Old Oct 25, 2011 | 01:17 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 92 accord engine swap (vtech)
K1llaturtl3 you may want to fix the title before the trolling commences. It's VTEC not vtech(electronics company)
VTEC
VTECH
Old Oct 25, 2011 | 04:53 PM
lol thanks
Old Oct 25, 2011 | 05:18 PM
This first image is the engine.
Name:  honda rebuild 013.jpg
Lets start with the mole hills...
Name:  extending the throttle cable.jpg
The first problem I ran into was the relocation of the throttle hanger. As you can see in the image I simply flipped it and held it in place with one bolt.
Name:  fuel line extended.jpg
Next is the fuel line it will need to be lengthened about 12 inches and ran behind the intake manifold.
Name:  honda rebuild 014.jpg
Next I ran into the fuel rail not bolting to the injector wiring harness rail thing (?). I zip tied mine for now.
Name:  exhaust not fit.jpg
The exhaust does not match up, because the vtec comes to two pipes and the f22a is a single.
Name:  alternator fitting.jpg
Name:  alternator fitting .25 gap.jpg
steering pumps mount matches up for the most part but there is an arm that would bolt to the head; on the vtec there is no hole for the bolt
Name:  honda rebuild 012.jpg
The IACV is located on the back of the intake, so the two wires need to be spliced and lengthened.
Name:  honda rebuild 043.jpg
The vacuum hoses also need to be lengthened
Name:  switchout pipes.jpg
And the pipe located on the back of the block needs to be swapped out with the vtec's.
beaver95
Apr 13, 2012 08:18 PM
92_Integra_GSR
Mar 27, 2009 09:56 AM
true-elements
Apr 18, 2008 02:53 AM
blackmfoggie
Jul 12, 2007 05:54 PM
Jester0754
Dec 20, 2006 09:32 PM
