HELP! Hasport h22 Crx axles combination???
Old Oct 25, 2011 | 12:20 PM
1slowcrx's Avatar
Default HELP! Hasport h22 Crx axles combination???
Have a Crx with hasport h22 mounts. H22 halfshaft. H22 inners and integra outer cups. Which OEM shaft from what car would be the right length??????
Old Oct 25, 2011 | 01:28 PM
ESP.net's Avatar
Default Re: HELP! Hasport h22 Crx axles combination???
Only OEM option would be 88-89 teg axles, from there custom.
Prelude Inners and midshaft are longer in length then 90-93 Accord midshaft female to male, female to accept a complete OEM 88-89 Teg axle on driver side. I believe Prelude inners are longer then Accord.
Old Oct 25, 2011 | 02:17 PM
1slowcrx's Avatar
i have a set of hasport axles that i snap last week at idrc. i got them rebuilt locally but they must have put a longer shaft cus its binding to the point where you cant even drive. any measurements??? im already in it $250 and axles still not working
Old Oct 26, 2011 | 10:23 AM
ESP.net's Avatar
Well I would say first thing first, go the better route. Get a 90-93 Accord Midshaft male to female, female side on axle inlet accepts the 88-89 Acura Integra Driver Side axle. Try a 88-89 Integra Passenger Side Axle with Accord/Prelude inner.
The less swapable parts you have with an OEM axle the better...
Once axles are in and in hub, tap the end of the axle in till it is compressed, pull it out with axle nut if you have 1/4" or more of play you should be fine.
If you have no play you will need to call Raxles.com ask for Marty. Order the same thing with 1/2" shorter shafts...
Old Oct 26, 2011 | 04:39 PM
1slowcrx's Avatar
Just got a chance to look at it, and the right axle and possibly the left axle are too long! I'm take it out and get some better measurements and See what the rebuilders can do for me
Old Oct 27, 2011 | 04:11 AM
1739gvr4's Avatar
Why not just buy these?
http://www.driveshaftshop.com/import...ale-right-male
they also have axles for a higher hp but that costs alot more
Old Oct 27, 2011 | 06:35 AM
gringo7718's Avatar
Call Raxles. (888) 257-8192 or (800) 257-8192
http://www.raxles.com
They are extremely knowledgeable and helpful with a quality product. I have been using their axles in my DD for 5+ years. I was done changing napa axles every couple of months and called these guys - havent even thought about axles since, only to recommend Raxles.
Old Oct 27, 2011 | 08:07 AM
1slowcrx's Avatar
Originally Posted by 1739gvr4
wish I would of did a Lil research before I did a impulse fix and now I'm out $250 with a seT of axles that needs 2 be re-done again cus they were too long. Would of picked up the DSS for $299 anyday
Old Oct 27, 2011 | 09:06 AM
CRX Toad's Avatar
Call the Hasport they can tell you 100%. Talk with Chris.
cycopath
Sep 7, 2008 06:23 PM
philafelman
Honda Civic (2006 - 2015)
Feb 4, 2008 06:15 PM
hondaguyexsi
Jun 23, 2005 08:01 AM
ItzTw
Feb 6, 2003 06:05 AM
Zane
Oct 6, 2002 04:27 PM
