97 accord f22b1 not receiving fire?
Ok so I cracked the head on my 92 Accord and replaced it with a v tech out of the 97. I had fire for about five minutes then I turned it off. I came out later that night and my battery was dead, so I recharged it and tried to start the car. I had no fire and have had none since.
I have changed the ignition coil, distributor, plugs and wires, main relay, the block is grounded as well as the ground under the thermostat. Its is in time (I checked it 5 times). My main relay has been tested with a test light and all connections are working. I am going nuts trying to figure it out. If anyone can help please do.
BTW would not having my cam sensor plugged in cause it not to fire? lol
dude i have looked everywhere for it. where are they located? every post or thread i have read says it should be a wire harness that comes out from behind the timing belt cover, but I do not see it lol.
trinigalsweet30
Apr 19, 2015 06:39 PM
