00 civic si - how install speedohealer?
Old Oct 24, 2011 | 08:17 PM
darkcivic90's Avatar
Default 00 civic si - how install speedohealer?
zup! h-t i just installed my ap1 s2000 cluster to my 00 civic si and i need help on how to install speeddealer and ect modifry diagram/schematic....anyone done there civic before???i need diagram....i keep looking online about diagram seems the ect is easy but the speedhealer kinda hard...anyone if uv done ur lmk...post here or pm me for diagram...thanks...mahalo...
sorry if i posted this in wrong category....
thanks.....
Old Oct 24, 2011 | 08:18 PM
Default Re: 200 civic si research
i mean speedohealer not "speeddealer".....lol...
Old Oct 24, 2011 | 08:48 PM
low91rex's Avatar
My buddy just put an s2 cluster in his teg and its so awesome haha. Check out some of the K forums they do it the most.
Old Oct 25, 2011 | 08:47 AM
Former User's Avatar
Default Re: 00 civic si - how install speeddealer?
Thread titles MUST summarize the tech problem (be topic specific) so that members browsing titles can understand the problem without reading the post. Title edited.
Old Nov 2, 2011 | 03:54 AM
linkdeezie's Avatar
"00 civic si - how install speedohealer?" <--- pretty much did it for me....he wants to know how to install speedo healer in a 2000 si....maybe blue...maybe red....didnt really specify car color...but i dont think that would be necessary
Old Nov 2, 2011 | 04:36 AM
grumblemarc's Avatar
The Grumpiest
Do you read? Ron edited the title for him to reflect the actually issue.
Title edited.
Old Nov 2, 2011 | 01:21 PM
chasingadrenali's Avatar
Default Re: 00 civic si - how install speedohealer?
has anyone figured this out? ive asked the same question many times with no help. i dont even know which speedohealer to buy.
Old Nov 2, 2011 | 03:29 PM
motegicivic's Avatar
Why don't you contact the company?
Old Nov 4, 2011 | 09:34 AM
vinem1's Avatar
Does anyone where can you buy one of them already converted? Like just plug and play ? that be nice if anyone knows?
Old Nov 5, 2011 | 07:46 PM
Bartman201's Avatar
x2
Old Nov 29, 2011 | 05:52 PM
anyone know how???thanks.....
Old Jan 27, 2012 | 09:04 PM
Jrkej1's Avatar
So no info on this....??????
Old Jan 28, 2012 | 06:20 AM
Jimster480's Avatar
wth is a speedohealer... If your speedo reads wrong figure out the difference in the voltages/resistance and get some resistors to change it up.
Old Jan 28, 2012 | 06:38 AM
The Grumpiest
The speedohealer is supposed to do just that or convert analog to digital or something.
http://www.azht.net/forum/showthread.php?t=148311.
"---------------------------------Speedohealer--------------------------------------
Speedohealer
Red to Ignition Power A3 on EG cluster
Black to Ground
Green to B7 Blue/White on S2000 cluster
White to B2 on EG cluster plugs"
Old Jan 28, 2012 | 03:00 PM
NotAJDMFanBoy's Avatar
I believe the way the speedo works is the VSS sends a 5 volt signal that switches on and off, the speedometer reads these pulses and how fast it is switching on and off determines the "speed". So the speedohealer must take the input of X pulses per second, and either multiply or divide that by a value to give the corrected speed.
Old Jan 28, 2012 | 03:09 PM
The Grumpiest
Really don't care HOW it works. I don't think it's an issue. They wanted to know how to install it was all.
Old Jan 28, 2012 | 03:12 PM
Actually, the speedo supplies the voltage and the VSS provides a pulsing ground, the rate of which reflects the wheel/transmission speed.
Old Jan 28, 2012 | 03:18 PM
Dc4LsTeG's Avatar
EK9
They do make a plug and play harness for this I've seen. But its like $400
Old Jan 28, 2012 | 04:12 PM
Ok, I was having speedo problems a while back and I was checking the signal wire and would either get voltage or not, so I was close, the sensor was opening and closing a circuit.
And to the guy who said he doesn't care how it works: tough, but I think understanding how things work make it easier to figure out a solution sometimes.
Old Jan 28, 2012 | 04:16 PM
The Grumpiest
It's not "tough". You were trying to correct me when It was clear that I didn't know or cared how the thing worked. Nor did anyone else in the thread. The question was getting installation instructions so that's what I tried to supply. Knowing how it worked was never relevant to the topic and still is not. I can splice two wires together and never need to understand a things inner workings.
Johnnygotkicks
May 15, 2010 11:24 PM
