main and rod clearances
Old Oct 24, 2011 | 07:41 PM
Kris's turbo's Avatar
Default main and rod clearances
Hey Im repacing the bearings in my f23, and wanted to know what the clearance range for the main and rod. Im going to run a straight bearing, this is not a race motor it is for just my daily beater. Thanks guys for your help.
Old Oct 26, 2011 | 05:43 AM
Default Re: main and rod clearances
anyone?
Old Oct 26, 2011 | 06:29 AM
Flagmichael's Avatar
.001-.002 - measure it with green Plastigage. I wouldn't know about that but a year ago my daughter's husband ran her 1993 Accord out of oil on the freeway and I had to replace the bearings to get them a few more months of service!
Anyway, .001-.002 is pretty much standard for engines that take 5W-30 oil, according to the mechanic at work.
Old Oct 26, 2011 | 06:57 AM
ok thanks is that for the main and rods?
Old Oct 26, 2011 | 07:06 AM
Yes - for both. I only replaced the lower halves of the main bearings because I was not going to drop the crank if I didn't have to, and the forces were mostly downward anyway, so I don't know much about special notes about the keyways on the mains. The rod bearings are keyed but I recall there was something counter-intuitive about which way the tabs went. Be sure to note that as you take the old ones out. Because the bearings are springy it is not possible even to do a sanity check on the fit without actually assembling them.
One of the frustrations I had was in getting the main bearing bridge back on. I had to rotate the crank to get the rods attached and that slid the thrust washers out of position. Be sure to tap those back into place with a drift before fitting the bridge or you won't be able to figure out why it won't go on.
Last edited by Flagmichael; Oct 26, 2011 at 07:08 AM. Reason: remove misleading word
jakscivic
Feb 21, 2013 08:27 AM
integra3586
19
Aug 25, 2009 09:31 PM
pjr710
Aug 18, 2008 11:18 PM
Chugger
Mar 8, 2008 12:53 PM
sixtodc4
Jan 20, 2008 09:33 AM
