PARTOUT: SOHC GOODIES...VENOM..PRECISION..TIAL..THERMAL..DENJI.. CROWER..CP..ACT..SRP
ALL THESE PARTS ARE OFF MY 94 TURBO CIVIC COUPE...EASIEST WAY TO GET IN TOUCH WITH ME IS TO TEXT...OR CALL...ALSO YOU CAN EMAIL ME AT DKID81@YAHOO.COM IF THAT'S EASIER FOR YOU...I AM NOT ON HERE OFTEN...THESE ARE NOT ALL THE PARTS..I DO HAVE SOME OTHER STUFF LAYING AROUND...IF YOU NEED SOMETHING JUST ASK I MAY HAVE IT...SOME OF THE ITEMS I WILL NOT SHIP BUT ASK AND I MAY BE WILLING TO WORK WITH YOU...PRICES DO NOT INCLUDE SHIPPING...AND LOW BALLERS DONT EVEN ASK...PLEASE DONT WASTE MY TIME!!!! THANKS..SHAWN 847 366 2081
- 92-95 CIVIC COUPE/HATCHBACK CERTIFIT FENDER..RIGHT/PASSENGER SIDE..NEW...$60
- BARELY USED NITTO NT555R DRAG RADIALS..205/55/14..MOUNTED ON 90 INTEGRA WHEELS..$160...SOLD!!!!!!!!!
- GM 3 BAR MAP SENSOR FOR TURBOCHARGED CARS...$30...SOLD!!!!!!
-PRECISION 880CC TURBO INJECTORS..LOW IMPEDANCE...$220
-92-95 HONDA CIVIC WASHER FLUID TANK/W DUAL PUMPS FOR THE HATCH SETUP...$10
-2X 3" 3 BOLT EXHAUST FLANGES AND 1 GASKET...$5
-2 BRONZE DRAG WHEEL CENTER CAPS..$10
-92-95 CIVIC SUNROOF MOTOR...$10
-3 92-95 CIVIC DISTRIBUTOR CAPS USED...$5 EACH...$10 FOR ALL 3
-92-95 CIVIC EX UPPER TIMING BELT COVER...$5
-SET OF H7 SLIM BALLAST HIDS I BELIEVE 8000K...$50...SOLD!!!!!!
-SOHC POLISHED VENOM INTAKE MANIFOLD...70MM SKUNK2 RACING THROTTLE BODY...DSM BLUETOP 450CC INJECTORS...-6 FUEL FEED BLACK BRAIDED LINE...STR BRONZE FUEL RAIL...WITH FUEL PRESSURE GAUGE...$1000 SETUP...MAKE A SERIOUS OFFER!!!!! SOLD!!!!!!
-SOHC BUILT HEAD...MILD PORT N POLISH ON THE EXHAUST SIDE...SKUNK2 TITANIUM SPRINGS AND RETAINERS...CROWER STAGE 2 TURBO CAM...SKUNK2 CAM GEAR...MAKE AN OFFER...SOLD!!!!!!!
-D16Y8 BLOCK BORED .020 OVER...$100
-SOHC CROWER RODS W/CP PISTONS...STANDARD BORE...USED...$550 SOLD!!!!!!
-SOHC EAGLE RODS AND SRP PISTONS.... .020 OVER...USED...$350 SOLD!!!!!!!!
-SOHC GOLDEN EAGLE SLEEVED BLOCK..D16Z6 BLOCK...NEEDS A LINE BORE...$300....SOLD!!!!!!
-SOHC STREET LIGHT ACT FLYWHEEL...USED LOOKS PERFECT...$130 SOLD!!!!!
-SOHC STAGE 4 COMPETITION CLUTCH 6 PUCK SPRUNG...USED...GREAT CONDITION...$220 SOLD!!!!
-2 SOHC TRANSMISSIONS...DX TRANS IS GOOD...EX NEEDS A MAIN SHAFT BEARING...NEITHER OF THEM GRIND...MAKE OFFERS...
-3" THERMAL R&D CATBACK EXHAUST...STAINLESS STEEL..PERFECT CONDITION...USED...$350
-92-95 CIVIC COUPE SHIFT LINKAGE...$20
-B&M 92-95 CIVIC SHORT SHIFTER..USED...$50
-VALVE COVER..POWDERCOATED RED WITH SILVER LETTERING...WITH BREATHER SYSTEM COMING OFF THE BACK OF IT...BLACK N RED FITTINGS..WITH CATCH CAN...ALSO HAS DRAIN BACK OPTION INTO THE BACK OF THE BLOCK...I PAID OVER $450 FOR THIS SETUP...$300
-92-95 CIVIC STARTER USED $30...
-92-95 CIVIC ALTERNATOR...$40
-92-95 CIVIC DENJI HEADLIGHTS WITH CHROME HOUSING...WITH HIDS...THESE ARE BECOMING MORE AND MORE RARE...$200
-ALUMINUM RADIATOR WITH SLIM FAN...$80 SOLD!!!!!
-WHEEL ADAPTERS...I WAS GONNA USE AS WHEEL SPACERS FOR MY CIVIC...NEVER DID...25MM APPROX. 1 INCH...4X100 TO 4X114.3...4 ADAPTERS WITH BOLTS..IF USING AS SPACERS YOU NEED TO USED EXTENDED LUGS...$100
-VARIOUS OTHER CIVIC PARTS...TURBO...INTERCOOLER...PIPING...BLOWOFF VALVE...WASTEGATE...CRANKSHAFT..WATERPUMP...OIL PUMP...ENGINE HARNESS...MOTOR MOUNTS...BRACKETS...ETC...JUST ASK I MIGHT HAVE IT...
CALL OR TEXT ANYTIME..847 366 2081..SHAWN
If you need pics let me know..I'm not gonna post pics of everything..if you want it you'll buy it..most people just like to talk....
MPF_supra
Dec 16, 2006 04:42 PM
MUGENTYPER
Dec 6, 2002 09:27 AM
