How hard is it to replace a starter in an EG
Old Oct 24, 2011 | 12:58 PM
Relick!'s Avatar
Icon2 How hard is it to replace a starter in an EG
So my car is having issues starting. I checked the battery and terminals and there all fine. I changed the relay last summer.
my daily comuter car has over 200k miles on it now. It sometimes struggles turing over and it's very slow and sluggish turning over when i try to start my car but once it's fired up the car starts and works like a dream and the engine still sounds strong. it's just the initial startup that it struggles on.
So obviously i dont want to spend a lot on it since its old. How hard is it to change a starter? does any one have links of how to do it (with pictures always helps). I'm trying to figure out if it's worth taking it to a shop that'll charge $250 or try to replace it at home...
TIA!
Old Oct 24, 2011 | 01:11 PM
92lxsleeper's Avatar
Default Re: How hard is it to replace a starter in an EG
takes about 10 mins and is 2 bolts and 1 bolt for the B+ and 1 spade connector for the solenoid. 12 or 14 mm. can't rememver.
Old Oct 24, 2011 | 03:34 PM
Relick!'s Avatar
thanks 92. anyone know of a good picture diagram for replacing it? i want to do thsi tonight.
if anyone does please email deltron50@hotmail.com or post here TIA
Old Oct 24, 2011 | 04:49 PM
24TEN's Avatar
PHANTOM MENACE
"92lxsleeper" is right on point. Do yourself a favor and disconnect the battery when doing this. I usually skip this step but one of the wires is directly from the battery and when you are using a ratchet it's easy to ground out to something and blow a fuse.
A picture does help but if you look in your engine bay it's pretty apparent which bolts need to be removed (it's only 2 total holding it in). The tricky one is the one underneath the starter, probably have to "feel" for that one in particular.
Old Oct 24, 2011 | 08:44 PM
Wrona's Avatar
took me 5 mins on my EJ6 which is thesame D series is all thesame
94integrals
Nov 7, 2014 11:10 PM
JC95Hatch
Feb 26, 2012 05:04 PM
95lowbuck
Feb 3, 2011 03:04 PM
RaVer24
Feb 12, 2009 08:54 PM
tree
Sep 21, 2003 04:45 PM
