built b18b1 bogging problem
hello, i am a new user and im desprite for help. i have a civic with and obd1 b18b1, it was running fine but now it bogs out when u rev it, and the air fuel ratio is maxed it rich 10.0. so i took the 780cc injectors out and put 480cc in but tht still didnt help, it took the back firing and the poping out but still bogging when i rev it, the car just falls on its face. it idles fine fires up fine but when revd fast or not even that fast it bogs out, so please if you have any ideas id appricate it alot.... im dieing to drive it with the new set up before it gets to cold
thanks
thanks
Built for what? Turbo? Are you running any engine management? CROME, Hondata, Neptune, Ectune? Is the ECU stock? Changing injectors are going to do squat by itself. DId you upgrade and not tune/retuned? IS it even tuned in the first place?
yes built motor, turbo, my old setup was tuned on hondata s200 and we didnt change anything on the tune or ecu since we put the built motor and new turbo setup on, same ecu and s200 with my old tune should of still been on it, see just the other day it was reving fine with the 780s in it now its acting funny, it keeps bogging out when revd and its a brand new motor no miles havnt even got to set the ring in yet due to this problem
Are you datalogging? Wideband to monitor your AFRs? When you tune for one setup and then change it YOU HAVE TO GET IT RETUNED!!! It may have "run fine" last week but it aint now. Me I don't care either way. If I were you I'd AT LEAST go and ask a real tuner to look at it or take it to a shop.
g2turbo
Engine Management and Tuning
Sep 16, 2015 12:15 PM
xXx Justin xXx
May 26, 2003 11:04 AM
Diego Boost
Feb 26, 2003 11:10 AM
