swap advice?
Old Oct 24, 2011 | 07:58 AM
skill178's Avatar
Default swap advice?
found me a oldschool d16a1 motor for $300, anyone know what all i gota do to drop it into a 91 SI?
and also what all parts i gota yank from the teggy?
Old Oct 24, 2011 | 08:17 AM
jlicrx's Avatar
Default Re: swap advice?
the D16A1 is not a direct swap into the 91 Si - the D16A1 has different mounts, different starter attachment and slightly different bolt pattern where the transmission bolts to the engine - you will need to fabricate a new driver's side engine mount as the D16A1 mount is on the front (toward radiator) side of the block and not on the end like the 88-91 engine - there are no holes in the end of the block for attaching a mount - the D16A1 block does not have a hole for the long starter bolt - you would need to bolt it to the transmission case - the bottom rear bolt for the transmission doesn't line up - you would need to elongate the hole in the block in order to get the bolt in - if the D16A1 is 86-87, you will have several problems with the distributor as the 86-87 D16A1 used a vacuum advance ignition system - if the engine is 88-89, you will need to swap distributor connectors and wire up the cylinder sensor on the end of the exhaust camshaft
Old Oct 24, 2011 | 08:30 AM
skill178's Avatar
will any DOHC's bolt in directly? i can live with wiriring issues and stuff but i dont wana fab mounts... lol
DOHC ZC?
though i do know the A1 is the only USDM DOHC :c
Old Oct 24, 2011 | 09:47 AM
jlicrx's Avatar
the only DOHC D-series engines that will bolt right in are: 88-91 JDM DOHC ZC - 88-91 European D16A8, D16A9 or D16Z5
you can use the 92-95 JDM DOHC ZC with a few modifications
Old Oct 28, 2011 | 11:31 AM
skill178's Avatar
you was talkin about the tranny and starter crap not lining up, can i use the tranny from the 88-89 integra too?
Old Oct 28, 2011 | 11:41 AM
JDpower's Avatar
I dont think you get what he is trying to tell you. No matter how you look at it if you want to put a d16a1 into an ED (ef) you will have to custom fab your mount(s). There is no USDM dohc that will swap in directly. Since you said you dont want to make you own mounts if you haven't bought the d16a1 yet I wouldn't buy it and if you have I would try trading it for something else.
Old Oct 28, 2011 | 11:47 AM
///Mathew's Avatar
You should buy a 3rd generation Civic (86-87), and swap it into that. Would make for a fun car!
Old Oct 28, 2011 | 12:26 PM
jlicrx's Avatar
not unles you make mounts for it - it mounts completely different from 88-91 CRX/Civic transmission
Old Oct 28, 2011 | 12:36 PM
singlecamsaint's Avatar
what he said, you dont see many folks fooling with those anyway. at least not around here
roscomojo
Honda Civic (2001 - 2005)
Apr 17, 2017 07:36 PM
ej1b18c1
Aug 8, 2012 09:01 AM
freddog509
Dec 16, 2008 02:19 PM
androO
Nov 13, 2007 01:25 PM
gsrcivic619
Apr 8, 2004 05:30 AM
