691whp 429 torque on stock sleeve B20
Old Oct 23, 2011 | 08:02 PM
V-SPEC 1's Avatar
Default 691whp 429 torque on stock sleeve B20
B20/Vtec Stock sleeve block
Forged Internals
Golden Eagle block guard
GT42r twin scroll turbo
Full-Race t4 devided topmount manifold
4" Up pipe
Tial Wastegate
Synapse BOV
Precision 1600cc injectors
FJO injector driver
Garrett core intercooler
3" aluminum piping
RPM 76mm TB
Hondata Intake manifold gasket
Hondata 4 bar map sensor
T1 turbo blanket
VictorX intake manifold
Skunk2 composite fuel rail
Aeromotive Eliminator fuel pump
Aeromotive fuel controller
Aeromotive fuel filters
AEM fuel regulator
MSD Digital 6 ignition box
MSD HVC2 coil
Avid Pro series solid mounts
Earl Pro-lite 350 hose -10AN feed -6AN return
OEM ITR water pump
OEM ITR oil pump
OEM ITR timing belt
Golden Eagle head gasket
Golden Eagle cam gears
ARP head studs
B16a head w/ Ferrea valve train
Skunk2 cams
Hondata S300 w/ boost by gear
Mac boost solenoid
V-Spec custom made 6061 aluminum catch can
V-Spec custom made battery relocation kit
1st pull on the dyno at 15 psi:
This video was taken at 18 psi pull:
http://http://www.youtube.com/watch?v=ghDA8xOxfzw
This video was taken at 25 psi running little rich before the final run but the camera man forgot to turn on the camera lol.
http://www.youtube.com/watch?v=9wxz46Gzw-E
Here's the final result of the day still on 25 psi:
Old Oct 23, 2011 | 08:09 PM
spectacle's Avatar
Default Re: 691whp 429 torque on stock sleeve B20
pics broken
Old Oct 23, 2011 | 08:18 PM
V-SPEC 1's Avatar
Originally Posted by spectacle
pics broken
Sorry, working on it now.....Damn photobucket lol. Ok, it should be working now
Old Oct 23, 2011 | 11:36 PM
.CUBISH.'s Avatar
good job.... super brave...lol
Old Oct 23, 2011 | 11:49 PM
Mufasa's Avatar
King of Lions
Nice amount of torque there. I like it
Old Oct 24, 2011 | 12:33 AM
B20vEf9's Avatar
What were Sae numbers..?
Old Oct 24, 2011 | 05:41 AM
Silva Bullit DC4's Avatar
429 WTQ, holy cow, lol! I bet THAT'S a wild ride.
Old Oct 24, 2011 | 08:08 AM
met's Avatar
met
Congrats on such good numbers on a stock block. I hate the scaling on the graph, the torque and hp don't seem to be the same at 5252. Did you notice how your afr is jumping up to 13 at the end? Its real bad in the first dyno, that would make me nervous. I'm not sure with the graphs once again but it seems like your torque drops off at the same point the afr's go up.
Old Oct 24, 2011 | 09:05 AM
V-SPEC 1's Avatar
The lean you are seeing is where it hit the limiter. By the end of the day, it's just a dyno numbers and don't go by the dyno's wideband because it was reading leaner than my NGK wideband. Thanks for looking out.
Old Oct 24, 2011 | 03:58 PM
Tony the Tiger's Avatar
Hey V-SPEC, what kind of Skunk2 cams are you running? Any modifications done to the JG Victor-X manifold? The numbers look great, especially the midrange torque at 25 PSI.
Have you ever done any straight gasoline 91oct or 93 oct runs?
Old Oct 24, 2011 | 04:21 PM
V-SPEC 1's Avatar
The intake manifold is Port Match To the tb which is 76 mm inlet. 93 octane made 535 whp 300+ trq @ 18 psi same setup but different block same head before.
Old Oct 24, 2011 | 05:06 PM
Bseriescivic5's Avatar
whats the compression of that setup?
Old Oct 25, 2011 | 04:25 AM
4cylfiend's Avatar
Amazing. Super risky but you did it. Nice numbers man!
Old Oct 25, 2011 | 04:42 AM
EE2bitsk's Avatar
got damn!
Old Oct 25, 2011 | 06:47 AM
rhamlinii's Avatar
How long do you think it'll last at either power level?
Old Oct 25, 2011 | 08:14 AM
Professor_X's Avatar
im assuming you stood at 84mm, right?
Old Oct 25, 2011 | 12:42 PM
V-SPEC 1's Avatar
84.5 mm to be exact
Old Oct 25, 2011 | 12:44 PM
V-SPEC 1's Avatar
I'm not sure. We will see how long she last.
Old Oct 25, 2011 | 04:56 PM
Muckman's Avatar
Moderator in Chief
Amazing. How much static compression? Which Skunk2 cam? If its not a secret.
Old Oct 26, 2011 | 12:03 AM
V-SPEC 1's Avatar
Compression is right at 9:5.1. Skunk2 P1.
Old Oct 26, 2011 | 12:29 AM
effin's Avatar
holy cow trq
Old Oct 26, 2011 | 12:35 AM
Dioxine's Avatar
That much torque under that hood is something to smile about
Old Oct 26, 2011 | 02:42 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Originally Posted by V-SPEC 1
84.5 mm to be exact
DAM
Old Oct 26, 2011 | 02:51 PM
W!d3b0dYr3X's Avatar
nice numbers. especially the torque. this gives me high hopes for my build which is quite similiar except im going to a 2.2l stroker
Old Oct 26, 2011 | 02:57 PM
jdmadam's Avatar
84.5 mm to be exact
Those are some nice numbers but a cracked cylinder wall is probably right around the corner
