crx b swap smoking white
Old Oct 23, 2011 | 07:39 PM
Wesleycrx's Avatar
Default crx b swap smoking white
hey guys just swapped my alternator on my b18b1 crx. in order to do it i found it easier to pull my intake manifold off and pull the alternator out through the top.
but now she's smoking white and has a rough idle any clue? smell's very rich and has no power it bogs out when i give it gas in gear.
Old Oct 26, 2011 | 05:05 PM
regal8r's Avatar
Default Re: crx b swap smoking white
did you replace the intake gasket after you pulled the manifold? youre probably leaking coolant into the intake itself. white smoke=burning coolant, blue smoke=oil, and black smoke=youre running really rich...
Old Oct 26, 2011 | 05:10 PM
gringo7718's Avatar
There is a much easier way to get the alternator out. >>>>>>>https://honda-tech.com/forums/showthread.php?t=2986970
It may also be possible that small pieces of debris from inside the manifold, fell down into one of the cylinders and is just burning off. It all depends on how much smoke you are seeing.
Old Oct 31, 2011 | 10:02 PM
Wesleycrx's Avatar
forgot to mention i have the skunk2 intake manifold so i couldnt pull it up through
elmalouno
10
Apr 24, 2023 01:53 PM
chad122
Aug 15, 2009 12:15 PM
blue89hatch
May 9, 2008 12:07 PM
littleblue
Jan 25, 2006 07:13 AM
