Head gasket removal. Need help.
I have taken the head off of my motor to replace the head gasket. The motor is out of the car at the moment also. I have got most of the big chunks of the old gasket off but there are some spots still on the block and a lot still on the head. I used a razor on most of the gasket and then a scotchbrite 3m pad. I cant not seem to get the rest of it off. And there is quite a bit off it on there. I have heard of the pertex (I believe thats how to spell it) gasket remover spray can stuff. But im wondering how good that stuff will work. Any input on this would be great. Thanks.
You should NEVER use Scotch-Brite or ANY abrasive material on either of the deck surfaces... You must realize - it's aluminum and when you use abrasives on it, it eats away the material and causes low spots. This leads to improper sealing - given a composite gasket can conform to these for the most part but it's not a good practice to develop.
You can use brake cleaner, gasket remover, even carb and choke cleaner... I would use brake cleaner that doesn't leave a residue. Due to the nature of the OEM gasket there will be staining on the surfaces - it's fine.
The head Must be Machined MUSSSSTTT!!!
unless you want a head with wavy surface!
use a razor blade take your time and use brake cleaner to help!
NOTE: brake cleaner will evaporate very rapidly to dont spray it and expect it to soak in,
This is ture if the headgasket blew i wouldnt even think about putting it back together before have it checked out by a machine shop to make sure its not warped.
Yeah I have saw those tools. And the head gasket didnt blow. I just got a brand new head gasket for the motor in a trade, so I thought I would go ahead and put it on since the one that was on it has been on it for say 22 years. lol. Here's my two choices that I have, build a d16a6/z6 mini me and do it right, or just buy a b20 swap off a good honda motors website. Which do you guys think would be the best and the least cost.
new_climber
Honda Civic (2001 - 2005)
Aug 28, 2023 12:11 PM
YoungMoney_Twit
Jul 8, 2018 10:11 PM
