Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
What spring rates would you recommend for a daily driven crx ?
Old Oct 6, 2002 | 09:05 AM
model x's Avatar
Default What spring rates would you recommend for a daily driven crx ?
Posted: Sat Oct 05, 2002 2:29 am Post subject: spring rates for b16 90 si Delete this post
I have a 90 si shell that I'm building using parts from an 88 dx. I've already removed the sound deadening but some dynamatt style stuff will replace it and I'm using the 88 doors. So the car should be about the same weight as a stock si with more of the wieght over the front end due to the B16.
I drive the car daily so I don't want springs that are too stiff. I've driven in a crx with Eibach Sportlines and I felt they were very comfortable.
Would 325f and 375r be good? Or should I go heavier or lighter?
BTW I also have eibach sway bars if that makes a difference.
Old Oct 6, 2002 | 05:11 PM
Hracer's Avatar
New User
Default Re: What spring rates would you recommend for a daily driven crx ? (model x)
For over half a year our ‘88 crx si was being driven daily on the street and raced on the weekends. It was a street legal racecar and had 350lbs front 400 rear eibach ers springs using off the shelf Tokicos shocks and an adj. suspension technique rear sway bar. The balance was very good, but compared to other track only cars it had a little too much body roll. Still an ok setup for the track. On the street it was very nice (read: stiff). Compared to other street cars it had 0 body roll, but the ride never seemed too harsh. Definitely a decent street setup as well and made it a good street/track compromise. Good luck.
v4lu3s
Jun 27, 2016 11:35 AM
crxsleeper210
Suspension & Brakes
Jun 28, 2007 03:28 PM
JapJunkie
Feb 11, 2005 03:28 PM
Brett@SoloRacer.com
Sep 14, 2001 09:38 PM
Steve Ellsworth
15
Aug 3, 2001 02:47 AM
