What coolant do you use?
In helms it says use only genuine honda fluids...but as you know, how would never say use some other product, and that honda stuff is like 17 bucks for a gallon, and this is even premixed (so they double gip you).
I want to buy some prestone and make a 50%/50% concentration and just use that....
Would that be ok?
Would that be ok?
You should only use Honda coolant. Boron and Silicates I believe are the two chemicals in most coolants that Honda does not include due to them causing damage to aluminum I believe.
I would stick with Honda if you can afford it...you may be alright with some "safe for aluminum" stuff, but Ive also noticed it contains those 2 chemicals.
aww fawk...i guess i need like a gallon now and a gallon later...thats 34 bucks, plus the caliper clip, 8, plus the washers, another few bucks, and MTF.....thats close to 50
thanks guys
thanks guys
caliskier
Aug 11, 2008 08:50 AM
psychodog
Aug 17, 2002 10:19 PM
