NY fs/ft: 400 plus fwhp ef
I am testing water on my 1990 civic. I am interested in trades or to sell it outright. Car comes with 2 motors and extra parts. I have lots of reciets. Price very negotiable. Car is tuned on e85 and made 417 fwhp and 324 ft/lbs of torque @ 21psi spikeing to 25psi. I might be forgeting some stuff. Head has about 1000 miles on it.
585 414 3739
10k obo with extra motor
8k obo without extra motor
1990 Civic Std.
Engine:
d16y8 block 75mm bore
9:1 CP Pistons
Eagle rods w/ ARP bolts
ARP head studs
Honda main bearings
ACL rod bearing
OEM y8 oil pump ported
Aftermarket y8 waterpump
Bisi level 2.4 turbo cam
Super tech valve springs
Stage1 intake port job
3 angle valve job
New valve seals
New cam seal
Cometic head gasket
Z6 throttle body
Y8 edelbrock intake manifold
Aem fuel rail and fpr
Innovative 90a billet mounts
10" slim line fan
Dual core aluminum rad
Tranny:
90 si cable tranny
Obx lsd
Synchro tech carbon rebuild kit
Fresh honda mtf
Turbo kit:
CC-Fab miniram manifold
Precision SC-50 .48 ar exhaust just rebuilt
Tial 38mm wastegate w/ 1 bar spring
4bolt Vband adapter
3" downpipe
Welded 2.5" charge pipes
CCA 6" FMIC
Hks SSQ Bov
Rc 1000cc peak and hold injectors
Hallman pro manual boost controller
Tuner toys oil line kit
Chipped p28 on crome
Chassis+Suspension:
Clutch specialties 6puck unsprung clutch
New steering rack
New skunk2 camber kit
All new tie rods
K tuned traction bar
Stainless brake lines
Hawk hps pads
Super blue fluid
ARP extended lugs
Moteki extended thread open end lugs
Tokico illumina 5 way adj shocks
Skunk 2 coil overs
15" Rota track r2 wheels
Falken azenis tires
Comp v2 13x8 trak wheels
MnH 23x8x13 slicks
Energy suspension shifter bushings
eBay short shifter
MK3 vw jetta front lip
Black house headlights
New amber corner light
New amber bumper light
New rear brakes and e-brake cables
Interior:
91 Si front seats
88 Si rear seats
Integra arm rest + center console
Rear speaker pods
Autometer boost gauge
Autometer oil pressure gauge
Water temp gauge
Rywire obd0-obd1 conversion harness
Grant GT steering wheel
Pros:
Comes with a 0 mileage short block
75.5mm bore y8
Je pistons
Eagle rods
Golden eagle block guard
Micro polish crank
New bearings
Also a used y8 head with 650cc injectors
Cons:
Car could use a paint job but no rust
Going to need a head gasket
Sugg new rad
http://www.youtube.com/watch?v=WyP6F6x2n5Q
Uploaded at Picoodle.com
585 414 3739
1990 Civic Std.
Engine:
9:1 CP Pistons
ARP head studs
Honda main bearings
ACL rod bearing
3 angle valve job
New valve seals
New cam seal
Cometic head gasket
Z6 throttle body
10" slim line fan
Tranny:
90 si cable tranny
Obx lsd
Fresh honda mtf
Turbo kit:
4bolt Vband adapter
3" downpipe
CCA 6" FMIC
Hks SSQ Bov
Chassis+Suspension:
New steering rack
All new tie rods
Hawk hps pads
Super blue fluid
ARP extended lugs
Skunk 2 coil overs
Falken azenis tires
MnH 23x8x13 slicks
eBay short shifter
Interior:
91 Si front seats
88 Si rear seats
Rear speaker pods
Water temp gauge
Pros:
75.5mm bore y8
Je pistons
Eagle rods
Micro polish crank
New bearings
Cons:
Sugg new rad
1. No block guard on current motor?
2. What's wrong with the current headgasket?
3. What brand is the water pump (OEM Honda?)?
4. What's wrong with the radiator?
5. Is that a 2 stage paintjob (base/clear)?
6. Does it still have rear drum brakes?
Clean car!
Clean car!
No block guard
Its going. I get coolant in overfill. Car is sitting in garage till next year
Water pump i got from autopart international. I replaced a lot of parts when i put head on and was low on money so i bought a non oem water pump. I will be replacing head gasket and water pump with oem honda after christmas
Radiator fins are damaged in some areas from bad mount job of slim fan. That will be replace after christmas also
Car was red. Then flat black and right now its a rustoleum paint job from a actually paint gun. No clear
Yes still rear drums. Everything in rear has a few thousand miles. Including e brake cables
Thank you. Im just a little low on money right now to fix stuff.
BUMP! My old car!
Not a spot of rust on it and 400+whp in an EF whats not to love?
ps homoguy, pics were working last night, not seeing them now, maybe try hosting them elsewhere.
