JDM b16a, hesitation/sputtering/laggy bottom end??
Old Oct 23, 2011 | 01:23 AM
EusebioSam19's Avatar
Default JDM b16a, hesitation/sputtering/laggy bottom end??
94 eg cx with a 94 sir-2 b16a swap
-Greddy 4-2-1 header
-passwordjdm whale ***** intake
-omnipower 70mm throttle body
-skunk2 pro series intake manifold
-NGK plugs & wires.
Car also has idle problems from 1200-1600, throwing IACV CEL
But the problem in question is, when I take off from a dead stop you hear a sputtering until about 3k ish & is just laggy to get to 3k rpm then when I go WOT the car hesitates but if i go like 3/4 WOT it will run better, just seems like whenever I go full throttle it just goes nowhere I'm going faster going 3/4 WOT & even then it kinda feels sputtery hesitant
Ideas?
Also I have a question about the breather box, is their anyway I can delete it?
Old Oct 23, 2011 | 01:56 AM
Dioxine's Avatar
Default Re: JDM b16a, hesitation/sputtering/laggy bottom end??
You can delete the breather box if you get an oil catch can. I had to do this on my ls-vtec because it leaked like none other from the rear motor and it turned out where the box goes into the block was cracked.
Old Oct 23, 2011 | 04:05 AM
BryanM.'s Avatar
Resident Gearhead
Check ignition timing and mechanical timing.
NvUsEG6
Apr 16, 2009 08:50 PM
B16tyler422
Jul 13, 2007 02:32 PM
TurboB16A300Hpteg
Jul 2, 2007 02:00 PM
shiftgear8000
Jun 17, 2005 12:02 AM
TheHatchHog
Apr 23, 2004 03:08 PM
