91 Accord Ex hard cold starting/ missfire
Old Oct 22, 2011 | 03:14 PM
91hondaaccord's Avatar
Icon6 91 Accord Ex hard cold starting/ missfire
hello, i have a 91 Accord Ex auto. been havin problems with cold starts in the morning and throughout the day. the vehicle has 178000 on the tach and lookin to get a couple yrs outta of it before i rebuild and turbo for my son. Car is kinda wierd or stubborn cause some days its fine other days almost seems like it dropped a cylinder. been noticing since been getting colder here in northeast car has been doin it more often. when started in the morning it misses really bad and will only start and stay running if u keep foot on gas and keep rpm above 2000 for about 4 min and then will idle and run perfect. also been giving problems with startup after warmed up. so far i swapped out injectors, clean IAC valve , removed and clean throttle body, replaced wires,plugs, cap, rotor, fuel filter. fuel pressure is about 40psi on startup and only drops to 32 while running. all injectors r workin properly and have continous spark from coil to all cylinders. any feed back would be greatly helpfull. and no check engine light or codes present while happening either.
Old Oct 23, 2011 | 06:58 AM
Lost Again's Avatar
Default Re: 91 Accord Ex hard cold starting/ missfire
Assume no stored codes, like the ECT (code 6 I think)...this is the one for the ECU not the ones for the fans or temp gauge.
FITV...adjusted
Compression test-does it seem to turn over slow first thing in the morning.
Old Oct 23, 2011 | 09:54 AM
ya no codes at all that is what has me puzzled and ya compression is within spec and actually considering mileage is dam close. cylinder 1: 180, cylinder 2: 178, cylinder 3: 176, cylinder 4: 173
Old Oct 23, 2011 | 12:58 PM
cctgene's Avatar
Just curious, when you checked the compression was the engine hot or cold?
Old Oct 23, 2011 | 02:40 PM
i check compression both at operating temperature and ice cold about a 10 percent differance. i am a gm master tech and in gm vehicles that is acceptable but not sure on imports.
Old Oct 23, 2011 | 02:42 PM
ohh before i forget all parts replaced were honda direct replacement from dealer.
Old Oct 24, 2011 | 06:19 PM
Lost Again's Avatar
So no possible head gasket leak when cold....that is where I was going with the slow crank when cold-water/coolant does not compress well.
Check the FITV for proper adjustmet, air boost valve cleaning can't hurt.
Rare but I have seen where the ECT can be bad/out of spec and not set a code.
ATPblack91LX
Mar 24, 2014 05:14 PM
pay1920
Jan 28, 2013 11:01 AM
ef4real
Mar 21, 2011 06:23 PM
hdj20
May 27, 2010 10:21 AM
gator-dog
Jan 16, 2005 03:02 PM
