How do you force pass. window up '93 accord
My passenger window wont go all the way up, the motor is bad. its down about 1/4-1/2 an inch and rain is getting in. whats the easiest way to force that window up, or what to seal with. thanks
Just put both your palms on the window and have someone push the "up" switch on the door and push it up. Or just push it up, push the button and work your way up. Most Accords do that.
I just tried that, the window button doesnt do anything when pushed. im putting all my strength into it and trying to get the window up and it wont. im trying to avoid turning this into a huge project. thanks for your input
take the door panel off and remove window regulator motor (it has three bolts holding it into the door panel) and then unbolt the regulator (it is the bracket assembly that the motor drives) from the window and ... there u go. slide the window up and figure out how to make it stay up (any way u can)
