keys wont open door
Old Oct 22, 2011 | 09:48 AM
elecktro's Avatar
Default keys wont open door
so i bought a 97 civic EX 2-door yesterday and i was given two keys. the really weird thing is that one of the keys ONLY works for the ignition, and it won't unlock either door. the other key will only unlock the passenger side door, and the trunk, but won't unlock the driver door and won't start the ignition. what could possibly be the problem with my doors?
Old Oct 22, 2011 | 09:55 AM
Linked's Avatar
Default Re: keys wont open door
sounds like you have different lock cylinders in the doors
unless you want to live with it, your gonna have to have the dealer get door lock cylinders and a key made with the vin on the car
Old Oct 22, 2011 | 10:53 AM
virgineg6's Avatar
^this
Old Oct 22, 2011 | 11:11 AM
hyperblu's Avatar
Honda dealerships are able to rekey your doors with a cheaper kit without replacing the cylinders all together.
Old Oct 22, 2011 | 11:22 AM
elecktro's Avatar
i got it at a used car dealership, should i go to a honda one anyways?
Old Oct 22, 2011 | 04:28 PM
motegicivic's Avatar
As other said your ignition has a different key, maybe it was replaced.
Did they give you a keyless fob?
Does it still have the factory radio, if so you can get a fob and program it to work.
Does anykey open the drivers door then?
What are the chances it has a different drivers door lock and ignition key too.
Did you run a car fax on it, was it in an accident? I am wondering if the drivers door was hit, got a junk replace door and never changed over the lock cylinder.
Old Oct 22, 2011 | 07:19 PM
frankenghia's Avatar
Does the key that works the ignition hardly have any "teeth" on it?
CivicIvo
Oct 10, 2017 04:14 PM
ayau
Feb 10, 2013 01:45 AM
square_1
13
Oct 13, 2010 07:11 AM
awwsnap
Honda Civic (2001 - 2005)
Feb 3, 2010 10:47 PM
