Suspension & Brakes Theory, alignment, spring rates....
weight transfer help understanding plz
Old Oct 22, 2011 | 09:16 AM
mr sim's Avatar
Default weight transfer help understanding plz
Hi im trying to figure out basic weight transfer for drag
Is this correct for rwd maximum weight transfer to rear is front springs ride hight rebound and compression damper on max stiffnes and max ride hight and all the rear on softest setting
Would that gain maximum transfer to the rear drivability isnt a problem just want to know if that would be the way to gain max weight transfer
And it would just rverse for fwd
Cheers
Old Oct 24, 2011 | 12:49 PM
TunerN00b's Avatar
Default Re: weight transfer help understanding plz
Weight transfer is purely based off of CG height and acceleration force. Shock settings and spring rates don't change the amount transferred, just the car's reaction to the weight transferred.
If you want to transfer more weight (though I have no clue why anyone would), raise the CG, accelerate harder, or both.
Is there a real question in there we can answer?
Old Oct 24, 2011 | 08:50 PM
FlewByU352's Avatar
I've always set my rear rebound higher and my front lower for drag racing. It helps spring back quickly when preloading and shifting.
Old Oct 25, 2011 | 07:08 AM
94eg!'s Avatar
#1 Super Guy
Loved
For FWD, you want to keep weight on the front tires. Stiffer rebound front should slow the cars lift in the front end and thereby slow the transition of weight of the front tires. Softer rebound rear should speed up the dive help quicken the weight transfer to the front during a shift. I think the guy before me has it backwards. If you had adjustable everything it would go like this:
Front:
- softer spring
- hard rebound
- soft compression
- lowered height
- decreased droop
Rear
- harder spring
- softer rebound
- hard compression
- raised ride height
- increased droop
Of course it's all relative. What works in theory, is not always the case in practice.
BTW: While damper setting is opposite of RWD, you have to remember they have to contend with longitudinal torque from the motor. That means their shocks are not the same left to right. Transverse FWD doesn't have this issue.
Old Oct 31, 2011 | 10:02 AM
mr sim's Avatar
Thanks everybody for the help I understand it better now cheers
beanbag
Suspension & Brakes
23
Jun 14, 2008 05:59 AM
n-c
Oct 18, 2005 08:30 AM
tnord
May 1, 2004 07:55 AM
LX4CYL
Mar 28, 2004 09:20 AM
hondacivic4g
Dec 13, 2003 11:54 PM
