high idle after intake manifold and throttle body gasket change...HELP!
Old Oct 22, 2011 | 07:08 AM
cody_sandlin's Avatar
Default high idle after intake manifold and throttle body gasket change...HELP!
i changed the intake and throttle body gaskets and now it has a super high idle....what did i do wrong? Are the hoses in the wrong place? one on the nipples on the injectors is missing.....will that do it?
Old Oct 22, 2011 | 07:24 AM
jayWknight's Avatar
Default Re: high idle after intake manifold and throttle body gasket change...HELP!
Sound like a vacuum leak. Make sure all the hoses are reconnected to their correct locations. What nipple are you referring to? The injector protective pinto caps? Rent a vacuum gauge from your local auto tool store to check for vacuum leaks.
Old Oct 22, 2011 | 07:30 AM
the nipple is like a burn orange color, and right when u pull of the fuel rail their sitting on the injectors on the very top. the pinto caps might be what im talking bout not sure what theyre called. where are some possible things that might would have a vacuum leak?
thewrai6th
Sep 13, 2011 05:19 PM
Thatssojdm
Aug 8, 2008 08:42 PM
emooheo
Feb 24, 2008 04:54 PM
90AcuraIntegra04
Feb 4, 2006 02:18 PM
thundergrey94ls
Jul 9, 2005 04:43 PM
