1991 Honda Civic needs you help please..
Old Oct 21, 2011 | 04:07 PM
JustThaEF's Avatar
Default 1991 Honda Civic needs you help please..
Ok so i bought a 91 hatch and soon we had to replace the alternator belt because it was literally shredded anyways we replaced the belt and drove it home now the car won't start it will not even try to start i believe its the battery so we got a new one but i don't think i put it in right or something cause it still wont start at all please help, thanks
p.s. new to the honda scene so please be descriptive
Old Oct 21, 2011 | 04:09 PM
Clipsed's Avatar
Default Re: 1991 Honda Civic needs you help please..
check your main fuses above the battery, sounds like you may have blown one if it has no power at all...
Old Oct 21, 2011 | 04:20 PM
JustThaEF's Avatar
how do i check the fuse? and how do i replace them, how much would it be?
Old Oct 21, 2011 | 05:28 PM
Projekt_ED3's Avatar
The battery fuse i believe is one of the big ones held down by two screws. Right way to test it is to see if it has continuity with an ohm meter. Easy way to test is see if the piece of metal is seperated through the window on the top. They are like 3 bucks to replace them.
Old Oct 22, 2011 | 04:08 AM
TearSDMF89dx's Avatar
check your grounds too.... i went through 3 batteries 2 alternators and 2 starters before i found that my engine grounds were just barely attached....cleaned those up and its been problem free since
sproket13
Aug 12, 2024 05:52 AM
Jakeumm
Honda Civic (2001 - 2005)
Aug 2, 2016 01:19 PM
djrubio
Jul 18, 2009 07:41 PM
antiricer
13
Jan 20, 2007 02:52 PM
chadmasterc
Jul 29, 2003 02:11 PM
