engine knocking/tapping durin warmup
Old Oct 21, 2011 | 12:40 PM
Mentat Ghola's Avatar
Default engine knocking/tapping durin warmup
HEres the situation, b18c engine, rebuilt 1000 miles ago. Everything is new.
Just yesterday i noticed a weird knocking noise.
When i first start the car cold, it sounds normal for 1-2 minutes, then theres like a 2 minute period as it warms up where theres like a tapping noise, then as the engine reaches operating temperature the noise fades and completely disappears.
Its really stressing me out, car runs perfectly. Im not sure if its a lubricatrion issue, or ignition knock, or mechanical. I just switched to synthetic oil after the 1000 mile break in period. I dont know if thats at all related, Im not sure if this noise was there before this oil change, mayb e it was i just never payed attention.
Some more relevant info, the timing belt also needed to be retensioned, it was a little on the loose side.
what should I do? retorque head bolts? change oil/filter?
Old Oct 21, 2011 | 01:46 PM
Builda'Teg_92's Avatar
Default Re: engine knocking/tapping durin warmup
Did you use aftermarket pistons?
Old Oct 21, 2011 | 02:23 PM
Nippon gsr pistons, .25 oversized. I dont think its piston slap, the pistons were a tight fit in the cylinders.
Old Oct 21, 2011 | 04:55 PM
Markyboy's Avatar
If there not coated pistons if seen it,before slap when its child then they are fine once warmed up but if its not that then id be a lil woeried and checking the oil for shavings and being 100% that its not something that will cost me alot if its something I could prevent. Just what I would do
Old Oct 21, 2011 | 05:00 PM
v8killaz's Avatar
what the **** are you saying dude. speak english
Old Oct 21, 2011 | 05:06 PM
Dioxine's Avatar
There is a huge difference between a knocking and a tapping. Is it it like a rod knocking sound or like a valve lash tapping sound. Cause 90% of the hondas i built had valve lash tapping when started cold then when warmed up it went away. But that usually happens immedeitly after start up
Old Oct 23, 2011 | 10:45 PM
Its not very loud, if youre inside the car, you could barely hear it. youd have to know what youre listening for, and it only seems to tap at idle, if i rev it up to 1500 sound disappears.
could this be a bad head gasket? i was idling for a while at a drive thru atm and the motor got a little hot. more clues.
Old Oct 24, 2011 | 02:15 AM
Dioxine's Avatar
Detonation? Im pretty sure headgaskets dont make a noise when they go out.
Old Oct 25, 2011 | 04:14 PM
10psiLsEf2's Avatar
Cold start knock.
What oil weight are you running?
and did the noise start after the oil change?
Old Oct 25, 2011 | 07:51 PM
Originally Posted by 10psiLsEf2
Cold start knock.
Seems like changing the PCV valve has stopped the tapping. The old one was faulty, it was letting air go both ways. This time i spent 20 bux at the dealer instead of 4 bux at pep boys.
Old Oct 25, 2011 | 07:57 PM
10psiLsEf2's Avatar
could make sense. maybe it was a ping.
Pac______
Mar 23, 2017 11:35 PM
alperx
Feb 9, 2012 08:52 PM
da9pwnsu
Dec 7, 2005 07:32 PM
