Bolt broke trying to take bumper off, trying to clean lenses...
ok so i have a silicone sealant that bonds plastics, lens restoration kit, i go to take off my bumper and when i go to the bottom bolts to screw off they are so rusted, one of them breaks off and half the the thread piece is stuck in the hole. not to mention the piece that broke off of the bult is stuck in my 11mm socket and wont come off for nothing. i tried wd40, hammer and screw, nothing. so not only can i not clean my cleanses but cant get the bumper off or the bolt...
how do you post pics? i want to show how my lights look
Maybe someone cross-threaded in a SAE bolt. There are no 11mm bolts on a Honda that I know of. Post pics of what you are stuck on. If the bolt broke off, why can't you get the bumper off?
You will need to drill them out and either tap to a 12mm or Helicoil back to a 10mm... http://www.helicoil.com.sg/
I would just drill it and tap to 12MM. 94
i will as soon as i get the chance and because, like i said, now part of the bolt is stuck in my socket... so i cant use that socket to unscrew the other bolts, i have to buy a new socket or set. and its weird maybe its the Husky set i have or something, i know they're supposed to be 10mm, but im pretty sure. and i tested it, the 10mm i have does not fit, its a bit small, and the 11mm did, maybe its because its a cheap set i bought at home depot for like 20-30bux...? idk. but it is what it is, i still want to take the bumper off to clean my lamp housings and not only do i have to get someone to take out my bolt, now im out a socket and bolt that i have to find.
radishark
10
Oct 14, 2016 11:59 AM
