Clutch stuck please help
I am guessing he means 'it doesnt want to shift into gear' and you probably have to re-apply the clutch?
It could be one of the following:
Bad clutch master cylinder
Bad clutch slave cylinder
Bad pressure plate
Low clutch fluid
Tranny fluid is low (Might have a leak?)
Bad pressure plate
Low clutch fluid
Check your clutch fluid resevoir ( smaller one next to the brake resevoir) get some DOT 4 fluid and fill it to the line. pump the clutch for a couple minutes then check again.
