How hot is the average heat in a car
Old Oct 20, 2011 | 03:10 PM
curtie94's Avatar
Default How hot is the average heat in a car
I was just curious how hot the air should come out at high.
The car is a 1991 Honda Accord 2DR LX
Old Oct 20, 2011 | 06:50 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: How hot is the average heat in a car
That model year, around 80-85 F
Old Oct 21, 2011 | 03:21 AM
hondamark35's Avatar
the coolant is what.. 180° F? let's assume the heater core is not 100% efficient, 75% will work. The air will loose a little heat as it works its way through the ducting. That gets us in the ballpark of 115° F. Of course that's on recirc with the blend at full heat and at the vent, not the temp in the cabin.
you can test yours with a cheap kitchen thermometer in the vents. If you don't feel that it's as hot as it should be, check the blend door linkage under the dash and the heater valve at the firewall just below the throttle body.
Old Oct 21, 2011 | 07:34 AM
curtie94's Avatar
I tested at the duct with a cooking thermometer and it was 140 without recirc and 160 with. I think my heat is all set. It never used to be this hot before i flushed the heater core yesterday.
Old Oct 21, 2011 | 07:40 AM
hispanic panic's Avatar
you worry too much.
Old Oct 21, 2011 | 07:51 AM
curtie94's Avatar
No I went all of last winter with no heat, and it was cold -20 to maybe 25 Degrees F up here
luvmihatch
Mar 5, 2013 04:49 PM
dcurcic
Nov 23, 2011 06:06 AM
GAB2
Nov 19, 2008 04:44 AM
97turboteg
Feb 18, 2006 05:54 PM
Jet Black
15
Dec 12, 2004 01:57 PM
