ABS Integra Booster Work with Non-ABS MC???
Old Oct 20, 2011 | 07:09 AM
WhiteSlips's Avatar
Default ABS Integra Booster Work with Non-ABS MC???
94-97 ABS Integra booster
94-97 Non-ABS Integra master cylinder
All going in a 92-95 Non-ABS Civic
Will that all work together without having to redo any hardlines or having problems bolting the clutch pedal to the MC?
Old Oct 20, 2011 | 08:16 AM
lsturbo33's Avatar
Default Re: ABS Integra Booster Work with Non-ABS MC???
no. master cylinder and booster need to match. So either get the smaller non-abs booster. Which might be what is already on your civic if it's non abs. If that's the case your 15/16 <i think if i remember correctly non abs master cylinder might fit right on. Or use your larger abs booster that you already have and get the 1" abs master cylinder front an integra.
Old Oct 20, 2011 | 08:40 AM
WhiteSlips's Avatar
The Civic booster has the studs 45 degrees from where they need to be for the Integra MC to work.... I think I'm just going to break down and get the correct MC to fit my Civic booster. Sucks being broke.
87integra
Nov 13, 2015 06:22 AM
87integra
Suspension & Brakes
Nov 7, 2015 10:50 PM
crazyhouse2011
Nov 13, 2014 02:22 PM
WhiteSlips
Oct 21, 2011 05:27 AM
BCDS
Dec 10, 2008 04:04 PM
