Spark, No fuel. Need car badly this week
Old Oct 19, 2011 | 06:25 PM
civic89si666's Avatar
Default Spark, No fuel. Need car badly this week
Hey guys, I got a 95 cx with a b series swap. I redid the wiring harness and while doing that I did not touch a single injector wire. Now that i put it all back together it will not start. I checked for spark and I have it. Timing is good and the fuel pump works. There is just no fuel getting into the motor. Please help. I have searched and the only thing that came up is to add a ground wire to both the ecu ground and the main relay ground. Btw the main relay is new as well. Thanks for your help guys.
Old Oct 19, 2011 | 06:32 PM
Hidenplanvew's Avatar
Default Re: Spark, No fuel. Need car badly this week
fuel pressure?
Old Oct 19, 2011 | 06:44 PM
should be ok. I dont have a tester for it but it is definitely moving the gas. I loosened the bolt on the fuel filter and gas came squirting out
Old Oct 19, 2011 | 08:02 PM
thangnhocngheo's Avatar
check ur main relay
Old Oct 20, 2011 | 04:47 AM
main relay is new. i have another one ill try today though.
Old Oct 20, 2011 | 08:51 AM
StreetsideStig's Avatar
You may want to check out a fuel pressure test kit from the parts store, or just buy a gauge for about 30 bones. Pressure doesn't mean the right pressure. It will help you isolate the problem.
Old Oct 20, 2011 | 07:41 PM
Alright so, it has to be something with the wiring. Checked tonight and the main relay was not clicking at all. I am going to add a ground to the relay and a ground to the ecu ground and see if that helps at all. This sucks. I just re worked the whole wiring harness too.
Old Oct 21, 2011 | 05:46 AM
kiickz4dayz's Avatar
make sure your thermostat ground is tight
Old Oct 23, 2011 | 01:19 PM
Yup, tight and cleaned. Worked on it more today. added the ground and nothing. So the main relay is not clicking at all and when I plug the jumper in to get the code nothing happens. CHecked all the grounds and they are all good. I dunno what to do. Also the ecu is chipped with a phearable.net chip and I had a friend install it who has done plenty of chips before. Any help is appreciated. I need this car asap
Old Oct 23, 2011 | 01:21 PM
Also, which fuses does the power run through for the ecu? I know a wire runs from the ecu to the main relay but which one is it? thanks
Old Oct 23, 2011 | 06:44 PM
Former User's Avatar
1) Does the fuel pump prime?
2) Do the fuel injectors spray fuel when the engine is cranked?
3) Is there bright white spark at all 4 spark plugs?
4) When the key is turned to ON(II), does the CEL remain on steady?
5) Is the mechanical off by a tooth or two?
Old Oct 23, 2011 | 07:26 PM
1.) Nope
2.)No fuel that I know off
3.) I checked for spark and yes I have it.
4.)Yup. Steady cel
5.) Mechanical should be good but ill check tomorrow
Old Oct 23, 2011 | 07:32 PM
Originally Posted by civic89si666
1.) Nope
If you jump terminal 1 to terminal 7 in the main relay connector, does the fuel pump run?
If you jump terminal 5 to terminal 7 in the main relay connector with the key in ON(II), does the fuel pump run?
Old Oct 24, 2011 | 08:31 AM
1 to 7 yes. 5 to 7 no.
Old Oct 24, 2011 | 09:47 AM
5 to 7 no.
Did you have the key in ON(II)? If so, check whether 15A dash fuse 24 is blown.
Old Oct 24, 2011 | 11:55 AM
Just checked it. There was no fuse in that spot. Guess it must have been removed while I was working on the car. Too bad my battery is dead. Once I get a chance to just it we will see if it runs.
Old Oct 24, 2011 | 12:22 PM
The engine definitely won't start or run without a good fuse 24 installed.
Old Oct 24, 2011 | 12:23 PM
Good fuse in. Tried to start. Still not running but a cel popped up as i cranked. Im going to check the cel. Is there another fuse for main relay and fuel pump?
Old Oct 24, 2011 | 12:25 PM
Check whether fuse 24 blew while you cranked the engine.
Old Oct 24, 2011 | 12:35 PM
Fuse 24 good. Threw a code 4. Which is a crank position sensor? We don't have them on our car do we?
Old Oct 24, 2011 | 12:38 PM
jerichofamm's Avatar
Ingnition control module
Old Oct 24, 2011 | 12:48 PM
Cool. I got another one of those in the garage. Let me switch em out and see what happens. I checked the plugs and it seems like theere is no gas getting squirted on them and the pump is working. But it still wouldnt start
Old Oct 24, 2011 | 01:17 PM
A bad ICM/igniter unit would NOT throw code 4.
For code 4, test the CKP sensor resistance and the two CKP wires for a short or open.
Does the fuel pump now prime for 2 seconds when the key is turned from off to ON(II)?
Old Oct 24, 2011 | 01:22 PM
no. I thought so but it is hard wired. The previous owner must have done it. Once I remove that wire the pump stops. I swithed the ignitor unit and still a code 4. Which wires are they? I don't have a tester currently.
Old Oct 24, 2011 | 01:23 PM
Return the fuel pump wires to stock. It's dangerous for the fuel pump to run constantly.
