top-most dizzy mount cracked
Old Oct 19, 2011 | 01:54 PM
SL33Pr_ProjeK's Avatar
Default top-most dizzy mount cracked
on the f22b HEAD...not the dizzy itself.
i was replacing the dizzy seals per the writeup in the FAQ section and when i went to remount the dizzy to the head i torqued the top head-post thing right off!
the other 2 dizzy mounts are secure, and the car runs like it should but theres a slight vibration in the dizzy now that might be unsafe at WOT?
can i JB weld that post back on to the head and be done with this? there are no internal parts exposed as a result of the break.
i will post pics here in a couple of minutes.
the good news is i def fixed my oil leak! any info you guys can provide would be helpful.
Old Oct 19, 2011 | 02:19 PM
Default Re: top-most dizzy mount cracked
hasty google image search and windows paint job...that is the piece that cracked off the head...the bolts at the base of that piece are still in tact.
i will have actual pics in a moment.
Old Oct 19, 2011 | 02:48 PM
so the question is: can i JBWELD this piece
back on to this point of the cyl head?
hard to tell in the pics, but the surfaces that would mate back up have a rough texture and they fit back together relatively cleanly.
Old Oct 19, 2011 | 03:06 PM
Dioxine's Avatar
Should be fine. Just make sure that you put all the other bolts in as well.
Old Oct 19, 2011 | 03:58 PM
the JB is curing now. i'll check it again tomorrow and possibly apply another coat.
thanks for posting sir.
Old Oct 19, 2011 | 08:16 PM
Dioxine's Avatar
No problem, i know how bad it sucks to get 100 views and no answers lol.
Old Oct 20, 2011 | 02:04 AM
GhostAccord's Avatar
Sounds like you may have had the distributor shaft 180 off. When you go to tq the distributor back on make sure the shaft is lined up/oriented properly to the cam (@ TDC) or it will do this again! JB weld or not.
JB weld is a band-aide fix IMO! Cheap but not always 100% reliable.
carbon fiber coupe
Nov 15, 2012 08:19 AM
VTECth1s
Jun 8, 2006 07:37 PM
WhiteGSR95
May 22, 2005 12:14 PM
kwik93si
Jul 23, 2003 03:53 PM
