coolant temp sensor and no start
Old Oct 19, 2011 | 10:43 AM
emu103's Avatar
Default coolant temp sensor and no start
dropped a d16 mini me (y7/y8) in a 96 coupe and have yet to get it running due to other problems that have come up.
my latest, and probably last problem is still causing no start.
i bought an obd scan tool to work with torque(android app) and pulled p0117
read the intake air temperature and its at ~74 degrees
however the coolant temp sensor is putting out 419 degrees. i had another running y8 so i pulled the sensor out of it and replaced the "bad" one
and the car ran for about 1-2 seconds. now i cant get it to run again
plugged my scan tool back in and got the same code, and the same temp reading.
im pretty sure if the sensor is telling the computer that the coolant temp is 419 then i absolutely know the fuel mixture is stupid lean, and probably my reason for not being able to get this engine running.
my next question is why are both sensors doing to same thing? is there an associated component i need to look at?
Old Oct 19, 2011 | 11:53 AM
motegicivic's Avatar
Default Re: coolant temp sensor and no start
You can manually test the coolant temp sensor with an multi meter to be sure.
Alexpbnj
Nov 17, 2010 05:18 PM
slammedz6ef
10
Feb 13, 2008 06:15 PM
turbociv
Jan 2, 2006 04:20 PM
rc90hatch
Dec 19, 2005 04:01 AM
90civichbsi
Oct 2, 2002 09:07 AM
