Voltage problems on my 1995 honda accord ex
What size battery is suppose to be in 1995 Honda Accord EX? My car has been upgraded with a VTEC 2.2 motor if that makes any difference. I have replaced the the power window motors and the SRS control unit and that has not fixed either of the problems. Windows get stuck rolling up and SRS light will not go off after reset. can anyone help?
Maybe. I don't know from memory what size battery. Go to O'Reilly or Autozone or Advance Auto website, put the year/trim level/engine in and find out. BTW, I think the VTEC engine was standard on your EX. In any case, before you buy a new battery, grab a $5 digital volt meter from Harbor Freight and check the battery voltage while the car is running. If it's 13 or 14 then there's enough voltage.
Power windows: did you clean & lube the window channels? Soap, water, and an old toothbrush works well. Let them dry and grab some silicone faucet grease from Home Depot or Lowes. Apply liberally to the clean channels. Maybe that will speed them up.
SRS light: did you reset using the yellow connector per step 7 of this post?
HOW TO: Bypass SRS for Aftermarket Wheel
Mikerugg
Nov 29, 2018 11:41 AM
Sean-45
Oct 6, 2017 08:37 PM
droppedHonda
Mar 20, 2012 12:37 PM
