Ls into ef
Old Oct 19, 2011 | 05:50 AM
Andrew_vaughn's Avatar
Default Ls into ef
Ok I wrecked my db1 and I'm getting a ef si..and I probably already know this but can I use the integra mounts for the swap or do I go carless until I can get aftermarket mounts??
Old Oct 19, 2011 | 06:40 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Ls into ef
You can use the T-bracket but that's it... All the other mounts will need to be from a kit. They have cheap ones on Internet for around $100... although if you have money to blow I recomend getting quality ones instead.
You should really read the FAQs as all this information is in there. There are even write-ups on how to do the swap and the parts that will be needed.
crxrida
Apr 7, 2013 07:10 PM
MasterLsGod
Oct 22, 2008 01:10 PM
nai90rts
Feb 24, 2008 04:40 AM
bLuBoOrEx89_RAZORS_
Jan 24, 2008 08:37 PM
