Bad Cat & Exhaust Valve on 3 cyl Help....
Old Oct 19, 2011 | 04:30 AM
juttsdm5's Avatar
Default Bad Cat & Exhaust Valve on 3 cyl Help....
Hello Team Honda !
so ive been getting Misfire on all cylinders. Im also getting a Cat-converter code .
I brought the car into a shop and they said i have a bad Cat as well as a bad seal (exhaust valve ) on cyl 3.
options are to get head work for $1500-$2000 car has 175k
or replace engine with one that has 75k for $700 plus labor.
now what im thinking, because i dont have that much money right now foreither option, is to replace the cat and then shut down fuel and spark to cyl 3.
im not sure how to do this. what do you guys think. is this a good idea for now. i dont want to mess up the good cylinder.
the compression on cyl 3 was 95. the rest are good.
thanks in advance for your help
Old Oct 19, 2011 | 05:12 AM
juttsdm5's Avatar
Default Re: Bad Cat & Exhaust Valve on 3 cyl Help....
also is shutting down a cylinder bad for your engine ? and where is the best place to shut it down. I was thinking the power supply going to the injector on 3 cyl
Old Oct 19, 2011 | 11:35 AM
MAD_MIKE's Avatar
MM Gruppe B
On these cars it is. If you remove the spark/fuel the engine will still mechanically pump air in that cylinder. This air will be pumped into the exhaust, the O2 sensor will read this pumped air, recalculate the A/F ratio and add more fuel, causing a rich condition.
Best bet would be to have the original problem with the engine fixed. Then if the catalyst was indeed damaged, have it replaced. Just because a code is tripped does not mean that the component itself has failed, just that it appears to have fallen out of expected parameters, and should be checked.
Old Oct 19, 2011 | 05:39 PM
Roader's Avatar
options are to get head work for $1500-$2000 car has 175kp
Awfully expensive for a valve job. Machine shops here charge $250 for the head work alone. Add six hours R&R labor and another $150 for a head gasket set. Even @ $100/hour shop labor rate the total would be right around $1000. Shop around. 175K miles isn't that much.
Old Oct 20, 2011 | 08:13 AM
juttsdm5's Avatar
thanks for the reviews, any other feedback ?
Old Oct 20, 2011 | 10:11 AM
SQ is the SQUAD's Avatar
also if you do replace the cat, keep your oem one, they are worth money. alot of shopd well tell you you need your cat replaced. then keep your old one and sell it for a profit.
i get a second option on both issues. bring it to somone who knows hondas and dont any anything about what the first shop said. if the valve seal is indeed gone you might be better off spending the money on a jdm h22 conversion or something along those lines.
Old Oct 20, 2011 | 06:29 PM
Accordman722's Avatar
GL lol
Old Oct 20, 2011 | 06:48 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Yeah, youre a tard. "shut down a cylinder" LoL. Madmike covered the rest.
Old Oct 21, 2011 | 08:52 AM
juttsdm5's Avatar
Dude, go smoke some Pen15.
For everyone else who was helpful, thanks !
Old Oct 24, 2011 | 08:39 AM
juttsdm5's Avatar
I replaced the cat converter. The car is running much better. The check engine light has not gone off in 3 days for misfire or cat. just a heads up.
Old Oct 24, 2011 | 10:11 PM
MAD_MIKE's Avatar
MM Gruppe B
Keep your eye on it. What may have happened is there was an exhaust leak, causing a lean misfire. Replacing the catalyst may have fixed the leak and lean misfire issue which in turn would fix the problem.
What were the codes, you didn't post the actual code numbers outside of 'misfire' and 'bad catalyst code'. BTW you didn't mention the year or model of your car.
Were any of these codes mentioned?
P0300 — Random Misfire
P0301 71 Misfire Cyl. 1 Or Random Misfire
P0302 72 Misfire Cyl. 2 Or Random Misfire
P0303 73 Misfire Cyl. 3 Or Random Misfire
P0304 74 Misfire Cyl. 4 Or Random Misfire
P0305 75 Misfire Cyl. 5 Or Random Misfire
P0306 76 Misfire Cyl. 6 Or Random Misfire
P0420 67 Catalyst System Efficiency Below Threshold
Old Oct 25, 2011 | 09:02 AM
juttsdm5's Avatar
2000 Honda accourd ex 4cyl 2.3
I believe the misfire codes were the
thanks for the feedback mad
jc007i
Jan 23, 2012 12:29 AM
donnie_437
Aug 22, 2007 11:08 AM
Erik_Pb_Foot
15
Nov 29, 2004 12:43 PM
sinatra
Aug 23, 2003 08:57 PM
jas_honda_uk
Mar 13, 2002 10:30 AM
