Competition Clutch Torque Rating
Competition rates their clutch by percentages. Is that just a percentage of the stock rating or a percentage over the stock allowance. Say I'm using a stage 5 clutch and the stock of a gsr's wheel torque is 115. 115 x 300% is 345ft lbs or is it 115 + 300% which is 460 ft lbs?
I have cleared by the companies that competition's numbers are wheel torque while spec clutches base their numbers off of flywheel torque. Beware!!
Email to Competition:
Thanks for the info. One last question. You rate your stage 5 at 300% torque
capacity. So with say 115 ft lbs stock would that equate to 345 ft lbs or is
it 300% over stock and would it be 460 ft lbs?
Answer from Competition:
Correct. 460ft lbs for a rough estimate of the holding capacity.
Now supposedly thats 460ft lbs of wheel torque and not flywheel torque. FYI
